tecateman Posted February 13, 2010 Report Share Posted February 13, 2010 as some of you may know by now im in the planning stages of my frame up build.... if i go with a 4 mil stroker 421 cylinder motor agressive dune or mild drag port,with cpi inframe pipes,vforce 3 reeds etc etc and im basically duning/hillclimbing/dragging....... what size carbs should i use? 35s? 38s? etc Quote Link to comment Share on other sites More sharing options...
01banch Posted February 13, 2010 Report Share Posted February 13, 2010 If your not all out drag racig I wouldnt go bigger than 35's. I might even consider some 33's or 34's. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted February 13, 2010 Report Share Posted February 13, 2010 we always had good results with keihin 35mm pwk. Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted February 14, 2010 Report Share Posted February 14, 2010 I would go 35's on a cub and they are a desent drag port out of the box. If you building a dedicated drag bike then I would go 39's Quote Link to comment Share on other sites More sharing options...
