Rodneya Posted February 12, 2010 Report Share Posted February 12, 2010 I saw an Australian site offering setups with 90 degree crankshaft. Anybody have experience with running something like that? Quote Link to comment Share on other sites More sharing options...
Rodneya Posted February 12, 2010 Author Report Share Posted February 12, 2010 Two Stroke Shop here is the link. Interesting stuff Quote Link to comment Share on other sites More sharing options...
NickisGod Posted February 12, 2010 Report Share Posted February 12, 2010 id call it a cheetah Quote Link to comment Share on other sites More sharing options...
THE358BANSH Posted February 12, 2010 Report Share Posted February 12, 2010 Man I thought these things vibrated bad enough all ready. I couldn't even imagine them with a 90 degree crank... Evan Quote Link to comment Share on other sites More sharing options...
vulvafan537240 Posted February 12, 2010 Report Share Posted February 12, 2010 i thought a kehin fcr was a 4 stroke carb? i want a rs500 though. whatever it is. it looks pretty mean and its a 2 stroke. ive heard of a rz500 but this looks like a modern day crotch rocket. Quote Link to comment Share on other sites More sharing options...
Rodneya Posted February 12, 2010 Author Report Share Posted February 12, 2010 id call it a cheetah The cylinders may be a cheetah, but I I did nit mention the cylinders. Read the heading. 90 degree CRANK Quote Link to comment Share on other sites More sharing options...
J.J. Posted February 12, 2010 Report Share Posted February 12, 2010 I had a chat with Steve via e-mail, he says that it should work great in off-road situations, should improve traction a whole lot. If it wasn't for the fact that you require a new ignition system to go with the crank I would've ordered a 4mm crank from him to try in a stock cyl set-up a long time ago. Drop him an e-mail, he's quite a friendly guy. Vibration should be less, not more. Quote Link to comment Share on other sites More sharing options...
Whitbread Posted February 12, 2010 Report Share Posted February 12, 2010 That's very interesting. Closer firing pulses would make the engine run and the power delivery be smoother. I may have to send them an email... Off topic, but that rs500 bike they build is straight up sex on 2 wheels . Quote Link to comment Share on other sites More sharing options...
Bansh-eman Posted February 12, 2010 Report Share Posted February 12, 2010 I have never talked with anyone thats ran a 90* crank, but it seems there would be spikes in power. For 270* of the cranks rotation there is no power then all of the sudden two within 90* of one another? Quote Link to comment Share on other sites More sharing options...
BSHEE400 Posted February 12, 2010 Report Share Posted February 12, 2010 I have never talked with anyone thats ran a 90* crank, but it seems there would be spikes in power. For 270* of the cranks rotation there is no power then all of the sudden two within 90* of one another? correct me if i'm wrong but wouldn't that make power more like a 4 stroke? Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted February 12, 2010 Report Share Posted February 12, 2010 I have never talked with anyone thats ran a 90* crank, but it seems there would be spikes in power. For 270* of the cranks rotation there is no power then all of the sudden two within 90* of one another? Yea that is what I would think. Feel like a inline four cylinder only running on 2 cylinders. Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted February 12, 2010 Report Share Posted February 12, 2010 I had a chat with Steve via e-mail, he says that it should work great in off-road situations, should improve traction a whole lot. If it wasn't for the fact that you require a new ignition system to go with the crank I would've ordered a 4mm crank from him to try in a stock cyl set-up a long time ago. Drop him an e-mail, he's quite a friendly guy. Vibration should be less, not more. I dont understand how a 90 deg crank would have a smoother power delivery and build more hp. If it is smoother, more tame wouldnt that feel like a power loss? Just like messing with the flywheel weight. You could put on a heavier flywheel and it would add traction by making for a softer hit. Quote Link to comment Share on other sites More sharing options...
dirtydownunder Posted February 12, 2010 Report Share Posted February 12, 2010 it all looks very nice but its got me fucked on how smooth and great its ment to be,even with a massive counter balance. his domes are different too. Quote Link to comment Share on other sites More sharing options...
camatv Posted February 12, 2010 Report Share Posted February 12, 2010 wow this guy has probably pushed the cheeta powervalve 2 stroke banshee engine into all new realms and ideas that are far out of the box. the 90 D crank has solved a LOT of problem if you actually think you will feel the loss of hitting 90* of center from 180* thats the same as saying you can feel the power loss of a 4 stroke it only hits every OTHER revolution. 620*! but somehow makes a ton of tq ( at least most of them) and can also be made to rev very high and have a similar powerband.. unless you have the technical knowledge to even understand what it is he was shooting for in driveablility and power band you dont really have any useable comments to these idea's unfortunatelly you probably wont hear of ANYone who has used this in the atv world the price of the motor is so high ( to cover development) its just not an average guy who's going to drop over 8000+ for a trail/ dune engine.. its unfortunate.. to use the 90* crank you will need a timeable ignition to fire the offset in the crank i was contemplating doing 2 banshee ignitions and timing the trigger OR possibly using an ofset timing mark with 2 pickups. not sure if i could fire the dead spark corectelly though . i have beenthinking of the 90* crank for a while untill i did a search and found that site. i'd love to have one of these engines.. Quote Link to comment Share on other sites More sharing options...
