terr1bleone Posted February 11, 2010 Report Share Posted February 11, 2010 What do you guys think is the best hooking 22'' tire for hardpack and some stone/dirt roads? Im having problems hooking up when launching, I just spin every gear unless im running a larger (12-14) paddle tire which gets torn up fast. I usually run 20's, stock 450 honda or yamaha tires. Ive had okay luck with 22'' mudlights. I tried an old set of atc bubble tires that measured out to 23'' I had laying around that didn't hook.. but really helped my gearing. Quote Link to comment Share on other sites More sharing options...
shanYE west Posted February 11, 2010 Report Share Posted February 11, 2010 I used to use realators.. Dont know if you can find them anymore though.. Quote Link to comment Share on other sites More sharing options...
morse250r Posted February 11, 2010 Report Share Posted February 11, 2010 they still make em just a heavy tire pro wedges are real good as well Quote Link to comment Share on other sites More sharing options...
terr1bleone Posted February 11, 2010 Author Report Share Posted February 11, 2010 realators and vampires are too small, they only measure out to 19.5. I heard pro wedges were only good till about 60hp.. I have a little over 90. Quote Link to comment Share on other sites More sharing options...
dajogejr Posted February 12, 2010 Report Share Posted February 12, 2010 Good luck getting 90ish to hook in the trails....especially in a 2 stroke power delivery. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted February 12, 2010 Report Share Posted February 12, 2010 sti dirt trax... they make them in a 22x11x9 that actually measures about 21". they are a really wide tire. rocky mountain sells them. Quote Link to comment Share on other sites More sharing options...
terr1bleone Posted February 12, 2010 Author Report Share Posted February 12, 2010 dajogejr- I know ill never deadhook, but im just trying to make it better then feeling like riding on ice. Loco- Thanks, ill check those out. I was also thinking about cut knarlys in 22''? Ive seen you run them hows the wear? or are they only good for grass/softer dirt. Quote Link to comment Share on other sites More sharing options...
QuadBart Posted February 14, 2010 Report Share Posted February 14, 2010 realators and vampires are too small, they only measure out to 19.5. I heard pro wedges were only good till about 60hp.. I have a little over 90. I run a raptor with a little over 200 HP and I use a 26inch realtor in dirt. BUT like was mentioned before. I m not sure that size is still available. I see your from the Chi-town area, I'm just north of you. You ever drive across the Wisc boarder and go to the MonkeyButt ATV races? You ever think about putting some Carbide picks in a set of tires and heading up To the Fox lake area to rides the lakes? Its legal you know. Believe it or not , you can make that thing Hook on the ice!! QB Quote Link to comment Share on other sites More sharing options...
terr1bleone Posted February 14, 2010 Author Report Share Posted February 14, 2010 (edited) I was talking about the popular size 22x12x10. Ive thought about bigger realtor's or vamp's but I think 25'' is the lowest like you said you run 26''. Im not sure i have enough torque to pull that big of a tire. Im more looking for the 22-23'' range when inflated to a couple psi. I haven't been to any races yet still gettin the bike sorted out. Ive ridden lakes in the past, It hasnt been too cold this year though didn't think that was going on. Edited February 14, 2010 by terr1bleone Quote Link to comment Share on other sites More sharing options...
QuadBart Posted February 14, 2010 Report Share Posted February 14, 2010 I was talking about the popular size 22x12x10. Ive thought about bigger realtor's or vamp's but I think 25'' is the lowest like you said you run 26''. Im not sure i have enough torque to pull that big of a tire. Im more looking for the 22-23'' range when inflated to a couple psi. I haven't been to any races yet still gettin the bike sorted out. Ive ridden lakes in the past, It hasnt been too cold this year though didn't think that was going on. Weve been riding the ice for over a month now but theres only a few more weeks left before it starts getting dicey again. Check out the link in my sig to hook up with riders/racers in Illinois Quote Link to comment Share on other sites More sharing options...
terr1bleone Posted February 16, 2010 Author Report Share Posted February 16, 2010 Im going with a 25x12x9 Titan Trail Claw 2, I found a local shop that has them in old stock. Ill be picking them up tonight, Im hoping with the lower profile they only measure out to 23''. Thanks to those who responded. Hopefully it works out. Quote Link to comment Share on other sites More sharing options...
