2"-1" up or 3"wide a arms?
BANSH-alena-jol-EE
I would measure it out and see what you can go. If you can pull off the +3's and not be wider than the rear I would go that way.
I have 20x11x10 tires on the rear and I could have gone +3 and been right at the same with as the rear. Not going to matter if the front end squeezes through if the rear wont.
  • Thanks 1
the +1 forward you will not really tell a diff any at all But I have only gone to +2 arms and always love them. I go for an offset rims for the dunes to make it a +3 and the reg tires for trail riding to keep those extra 2 for the trees. But if you go wide up front. Make sure you go wide in the back and your bike will handle like it is on rails.
If you ride tight trails, then +3s are going to give you a bit of trouble. What offset are your front wheels? To achieve the best handling, go with a 4x1 inset on the front wheels and roll with a set of +3 arms. You will have to replace your brake lines if you go with +3s, whereas you wont have to with the +2s. It will also be more imperative to have your shocks valved for +3s vs +2s. Just some things to consider. Either way you will be making a nice improvement over stock!
