Profilact Posted February 6, 2010 Report Share Posted February 6, 2010 Well guys, I have a problem. I've got a little extra cash to spend after buying all new bottom end parts and don't know what to do. I'm currently running DG pipes, which we all know are not the greatest thing since sliced bread. Problem is this: Do I spring for pipes, or have my cylinders ported? I'm afraid that the 4mil setup with stock bore will be a little disappointing without one or the other. Profilact Quote Link to comment Share on other sites More sharing options...
bansheesandrider Posted February 6, 2010 Report Share Posted February 6, 2010 Who's 4 mil set up is it? Without knowing that, it is hard to say. If the motor is apart, I would probably do the porting while you are in there. It is a pretty easy job to change the pipes after you get it running. Or, you can port it while it is apart and then see if you can find some better pipes while you are putting it together,so that once it is together, you only have to dial in your jetting once. Quote Link to comment Share on other sites More sharing options...
AKheathen Posted February 6, 2010 Report Share Posted February 6, 2010 porting.....you can buy the pipes later, when you can afford it.... Quote Link to comment Share on other sites More sharing options...
firebanshee Posted February 6, 2010 Report Share Posted February 6, 2010 Just have the cylinders ported to the pipes you want to run. Quote Link to comment Share on other sites More sharing options...
alf44 Posted February 6, 2010 Report Share Posted February 6, 2010 x2 port first then pipes. Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted February 6, 2010 Report Share Posted February 6, 2010 Yea if you already have the 4mill crank, and assembling the engine deffinatly have the cylinders ported. You might tell the builder what pipes you plan on changing too as well. The pipes just bolt on so they are easly changed later on. Quote Link to comment Share on other sites More sharing options...
FASTOYS Posted February 7, 2010 Report Share Posted February 7, 2010 You will be MUCH happier getting them ported now and changing pipes later!! Quote Link to comment Share on other sites More sharing options...
Profilact Posted February 7, 2010 Author Report Share Posted February 7, 2010 Ok Jeff looks like Ill be calling you Monday and sending my cylinders in. Quote Link to comment Share on other sites More sharing options...
RadarRacing Posted February 7, 2010 Report Share Posted February 7, 2010 Believe it or not but DG's banshee pipes run pretty good especially with a 200lb or over rider. Don't know what you weigh.If you just did the crank you will gain quite a bit due to the added port timing and CCs by going with more stroke but if you have Jeff do a play port on it you'll gain a bunch more. True sleeper 450 killer with doller general pipes. A friend is doing a 4 mil crank and putting on his old crappy set of DGs just for that reason. Quote Link to comment Share on other sites More sharing options...
Profilact Posted February 7, 2010 Author Report Share Posted February 7, 2010 I weigh 230, and dont get me wrong, I actually like the way the DG pipes hit, but I think I would get more out of the bike with a set of T5's or better. And now i see it like this: already have pipes, get the porting done. Quote Link to comment Share on other sites More sharing options...
RadarRacing Posted February 7, 2010 Report Share Posted February 7, 2010 Don't get me wrong it will run a bit better with different pipes like T5s but you'll gain 10 or 20hp by going 4mil with porting and then gain another few hp with pipes later. I'd take the 15 hp for a few hundred now. One thing about the DG pipes is they fall off powerwise after a few hard runs due to heat in the pipe and going bigger on the motor will not help that but should be fine unless you wanna hot lap wide open constantly. On the bright side a 4mil with those pipes can pull a boat.lol Quote Link to comment Share on other sites More sharing options...
FASTOYS Posted February 7, 2010 Report Share Posted February 7, 2010 450 killer with doller general pipes. Funny, i havent heard that saying in years. On the bright side a 4mil with those pipes can pull a boat.lol Lol, Is that like pullin the ass out of a Rhino off idle?? But yeah on a side note, as said the DG pipes do run pretty decent for a play bike. Strong bottom to mid with ok top end. Quote Link to comment Share on other sites More sharing options...
Profilact Posted February 7, 2010 Author Report Share Posted February 7, 2010 So FASTOYS all I need to do is pull these cylinders off and put them directly into a box with some rocks and dirt and send them to you right? Then they magically come back clean and sparkly? Quote Link to comment Share on other sites More sharing options...
FASTOYS Posted February 7, 2010 Report Share Posted February 7, 2010 Please clean them and scrape the gaskets. Pack them well including name and phone # with a note in the box and ship to http://www.farmandsandtoys.com/contactus.asp Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted February 7, 2010 Report Share Posted February 7, 2010 Include lunch money and he might clean them !!! Quote Link to comment Share on other sites More sharing options...
