yes the honda's use a 2 wire regulator and the yamaha's use a case grounded single wire. thats why the ground is mounted through the regulator on the oem wiring.. you should probably be able to just run a jumper to the ground when you mount it. just make sure you use it straight to the body of the regualtor. if no lights wont need it!
  • Replies 37
  • Created
  • Last Reply
Top Posters In This Topic
Looks good JD...
I'd think drilling the frame and self tappers would cure the ground issue...no?
Did I miss something?
Thanks brotha!
Yes, it will for raw aluminum Dave. My bracket is PC'ed which I will have to mask off the coil area on future orders that require PC. No biggie!
This bracket is a really clean look, Im happy with it on my build for sure.
If I didn't run a Nology Coil w/ hotwires I'd have one of these...keep up the good work.
Well, this does not mount the coil so you should get one lol! :rolleyes:
  • 1 month later...
