thbanshee81 Posted January 28, 2010 Report Share Posted January 28, 2010 My banshee is running great but my ride side pipe is smoking more than the other. the right spark plug fouls everynow and the and the left side is perfect. i was wondering if anybody else has had this problem with the right side being richer than the other. my airscrews are both the same. i was wondering if the clip on the needle could be adjusted to be different than the other carb? i would just like some input if someone else has had this problem. my mods are just piped and jetted its an 04 with pretty low hours Quote Link to comment Share on other sites More sharing options...
banshee-mike Posted January 28, 2010 Report Share Posted January 28, 2010 My banshee is running great but my ride side pipe is smoking more than the other. the right spark plug fouls everynow and the and the left side is perfect. i was wondering if anybody else has had this problem with the right side being richer than the other. my airscrews are both the same. i was wondering if the clip on the needle could be adjusted to be different than the other carb? i would just like some input if someone else has had this problem. my mods are just piped and jetted its an 04 with pretty low hours i had a similar prob and synching the carbs fixed it Quote Link to comment Share on other sites More sharing options...
thbanshee81 Posted January 28, 2010 Author Report Share Posted January 28, 2010 i synced them after i cleaned them real good so as far as i know they should still be good. ill check tho.. would that make that side run that much richer Quote Link to comment Share on other sites More sharing options...
Boston Posted January 28, 2010 Report Share Posted January 28, 2010 i synced them after i cleaned them real good so as far as i know they should still be good. ill check tho.. would that make that side run that much richer hey this is kinda off topic but i thought id ask what does it mean to sync your carbs? Quote Link to comment Share on other sites More sharing options...
banshee-mike Posted January 28, 2010 Report Share Posted January 28, 2010 i synced them after i cleaned them real good so as far as i know they should still be good. ill check tho.. would that make that side run that much richer are you using a synch tool? Quote Link to comment Share on other sites More sharing options...
thbanshee81 Posted January 28, 2010 Author Report Share Posted January 28, 2010 making sure the carb slide move at exacly the same thing there are srews on top of the carbs to adjust both. theres a good video on youtube showing u how to do it Quote Link to comment Share on other sites More sharing options...
thbanshee81 Posted January 28, 2010 Author Report Share Posted January 28, 2010 making sure the carb slide move at exacly the same time *there are srews on top of the carbs to adjust both. theres a good video on youtube showing u how to do it Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted January 28, 2010 Report Share Posted January 28, 2010 so one side keeps fouling? thats weird. if your jetting is the same and the carbs are synced then you have bigger issues. have you noticed any coolant loss? is the exhaust smoke from oil or is it really white and sweet smelling? have you checked to make sure you have good spark on the right side? Quote Link to comment Share on other sites More sharing options...
thbanshee81 Posted January 28, 2010 Author Report Share Posted January 28, 2010 no just eyeballed but they were pretty close... the card not being synced run richer than the other? Quote Link to comment Share on other sites More sharing options...
thbanshee81 Posted January 28, 2010 Author Report Share Posted January 28, 2010 coolants good, smoke is normal smoke, and yea ive tested the spark an its good an blue, would the carbs not being synced make it run richer? Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted January 28, 2010 Report Share Posted January 28, 2010 coolants good, smoke is normal smoke, and yea ive tested the spark an its good an blue, would the carbs not being synced make it run richer? that shouldnt have much to do with it. they would have to be way off to affect it that much. if you keep fouling plugs on that side then something is making it too rich. how far off do you think the carbs are? if they are pretty close, youre fine and thats not causing this problem. Quote Link to comment Share on other sites More sharing options...
thbanshee81 Posted January 28, 2010 Author Report Share Posted January 28, 2010 thats what i thought. they should be pretty close. im stumped Quote Link to comment Share on other sites More sharing options...
banshee-mike Posted January 28, 2010 Report Share Posted January 28, 2010 thats what i thought. they should be pretty close. im stumped they can appear to be close by eyeballing but i would reccomend using a synch tool, Quote Link to comment Share on other sites More sharing options...
thbanshee81 Posted January 28, 2010 Author Report Share Posted January 28, 2010 its one carb running richer than the other.. if them not being synced exact doesnt have anything to do with it than thats fine.. i just wanna kno why one is richer than the other Quote Link to comment Share on other sites More sharing options...
bansheesandrider Posted January 28, 2010 Report Share Posted January 28, 2010 Uhh, has anybody thought about the crankshaft seal on the right side. It could be sucking oil out of the clutch area, causing it to smoke. Check the tranny oil to see if it is going down, remember, a little oil makes alot of smoke ,so you may have to run it awhile and continue checking the tranny oil to see if it goes down. Quote Link to comment Share on other sites More sharing options...
