Ingram306 Posted January 25, 2010 Report Share Posted January 25, 2010 Ive decided instead of doing the TORS removal im going to swap out my stock carbs, the choke is screwed up on them anyway... Found a set of 28mm PWKs for a good price. Now im wondering if its worth the money, or if i should just go up to 30s or 33s? Ive heard i will lose bottom end with the 33s though... any ideas? Quote Link to comment Share on other sites More sharing options...
GNR101 Posted January 25, 2010 Report Share Posted January 25, 2010 Ive decided instead of doing the TORS removal im going to swap out my stock carbs, the choke is screwed up on them anyway... Found a set of 28mm PWKs for a good price. Now im wondering if its worth the money, or if i should just go up to 30s or 33s? Ive heard i will lose bottom end with the 33s though... any ideas? go the 28s u wont loose bottom end and will get a bit of power when u go the 33s etc u loose the bottom on a stock stroke.. and u nee to change the intake sizes etc.. Quote Link to comment Share on other sites More sharing options...
Building my First Posted January 25, 2010 Report Share Posted January 25, 2010 28 PWK are an excellent choice for a trail/woods/mx bike. You may be able to pull off 30's without losing grunt, if you have pipes that give you enough top end to use 30's. Quote Link to comment Share on other sites More sharing options...
LiftdT4R Posted January 25, 2010 Report Share Posted January 25, 2010 The 28s are good carbs, I ran them for a bit, and I liked the power delivery a lot. I did however have a little trouble getting them dialed in. Not too many people run them so it's a little tough to get really accurate jetting specs like you can with stockers. The choke knobs are also a bitch to deal with, each carb has it's own knob, and the one on the ?right? carb sits inside the bike where it is tough to get too depending on which pipes you run. Have you looked into a single carb setup? A lot of guys run them for trails and like the low end. I used to run one but I thought it kind of lacked the top end like dual carbs do, if you run a lot of wide open stuff like fireroads or fields you might not be happy with it. I'm running 34mm PJs on my bike now, and I like them a lot, they work pretty good in the tighter stuff, and haul when theyre wide open. I think they're pretty good all around carbs, but I would like to go back to 30s or 28s if I didn't have to mess around with the jetting so much. Quote Link to comment Share on other sites More sharing options...
jmoore Posted January 25, 2010 Report Share Posted January 25, 2010 I just ditched a 2 into 1 setup for some 28 pwk's and am very happy. It pulls much harder all the way through the powerband. Dialing them in for me was very simple. Definately recommend these!! Quote Link to comment Share on other sites More sharing options...
AKheathen Posted February 1, 2010 Report Share Posted February 1, 2010 the 28's should be perfect in the trails, if your whole setup matches. the single carb thing is mostly a myth. actually, you can get the stock carbs to 30 to out perform any single on the top AND bottom, if you just tune them right. Quote Link to comment Share on other sites More sharing options...
shanYE west Posted February 1, 2010 Report Share Posted February 1, 2010 stock carbs will perform well up to around 60hp.. if your in a pinch for money you could get the stockers bored to 28's and call it a day. You'll probably run into problems boring them to 30mm though. I'd probably just get 28pwks so you dont have to bother with the stock crap anymore.. Quote Link to comment Share on other sites More sharing options...
RadarRacing Posted February 2, 2010 Report Share Posted February 2, 2010 I would tell you to get your stockers bored but if they are messed up then the 28 or 30s work kick butt. Don't forget the OKO 28 and 30s they've worked well for me for years. Before anybody was selling them for banshees I was gettin em from Taiwan for use on scooters and using them.on banshees. Lean out the needle 1 clip put in some 52 pilots, 152 mains and roll. Quote Link to comment Share on other sites More sharing options...
wacko2000 Posted February 2, 2010 Report Share Posted February 2, 2010 Everyone is gonna have there opinions and different suggestions They are a thousands different thing you can do. So many options confuse the shit out of me so i know how you feel When i first went to a stroker motor, I ran bored stockers and the bike ran awesome. If money is tight, bore out the stockers I know a lot of guys that like a single carb setup for trail bikes also Its going to be preference. I think wether you stick with stockers or 30's you will be happy as long as its dialed in good good luck Quote Link to comment Share on other sites More sharing options...
lilmegill727 Posted February 2, 2010 Report Share Posted February 2, 2010 my 28mm pwk's did awesome on my shee. great all around power for an all around bike! Quote Link to comment Share on other sites More sharing options...
peterlocal22 Posted February 3, 2010 Report Share Posted February 3, 2010 Everyone is gonna have there opinions and different suggestions They are a thousands different thing you can do. So many options confuse the shit out of me so i know how you feel When i first went to a stroker motor, I ran bored stockers and the bike ran awesome. If money is tight, bore out the stockers I know a lot of guys that like a single carb setup for trail bikes also Its going to be preference. I think wether you stick with stockers or 30's you will be happy as long as its dialed in good good luck +1 Quote Link to comment Share on other sites More sharing options...
Wassup350 Posted May 17, 2010 Report Share Posted May 17, 2010 single carb set up is great! You dont really need that much topend for woods racing. Plus the single is so much easier to jet!! The stock carbs are the crappiest carbs made. When ever i'd get them wet they would rev to the moon. Quote Link to comment Share on other sites More sharing options...
87sheerips Posted May 17, 2010 Report Share Posted May 17, 2010 28mm PWKs, dune port, stock stroke, T5's with 165PSI, 14/41 gearing was a GREAT setup for the trails and everything else in between. Plus runs on pump gas (borderline) 35mm PWKs, dune port, stock stroke, CPIs, with 180psi, 15/41 was and IS an even better setup lol. Much more power everywhere especially on top. I love this setup on my trail/duner and will probly never change it, it rips. IMO, stock carbs suck and should be tossed instantly. I know they work, and they have surprised me before but they are just garbage. Quote Link to comment Share on other sites More sharing options...
camatv Posted May 18, 2010 Report Share Posted May 18, 2010 28's are great smooth bore to 30's neato too. i have 30's on my trail bike and 28's on my old trail bike.. all the other banshee's i have are running lectrons. i have a set that are runable BUT should have new slides in them i'd sell for 100 bucks.. Quote Link to comment Share on other sites More sharing options...
Washburn Posted May 18, 2010 Report Share Posted May 18, 2010 I absoluly Love my Single Trinity intake with a 35PWK for the tighter woods and trail XC Stuff. I noticed powergains everywhere espically lowend/mid preformance and it pulls harder on top than stockers. I wouldnt change it for duals. Ive rode both and I like mine but every banshee is setup diffrently. Quote Link to comment Share on other sites More sharing options...
