wvbansheeboy Posted January 23, 2010 Report Share Posted January 23, 2010 i have a 1992 shee that i have been goin thru with a fine tooth comb.. anyways i jus tried to change the front bearings and couldnt get the hub off is there a special trick or somthin took the spindle nut off even tapped on the back of it with a punch.. wouldnt budge . sprayed pb blaster all over it.. tapped the hub and the darn thing wont move.. and i got pivot works bearings are they any good? thanks guys any help appereated Quote Link to comment Share on other sites More sharing options...
LiftdT4R Posted January 23, 2010 Report Share Posted January 23, 2010 I would try a press. Failing that you could try using a 2 or 3 jaw puller to take it off, or even a little bit of heat from a torch although it will probably make a mess out of the oil seals. Quote Link to comment Share on other sites More sharing options...
stokes77 Posted January 24, 2010 Report Share Posted January 24, 2010 I had the same trouble with mine when I was doing the wheel bearings. What I did was get a buddy to pull on the hub as hard as he can and I used a wooden block and a little sledge hammer and just tapped on the end of the spindle while he was pulling. It actually came off pretty easily once we did that. Quote Link to comment Share on other sites More sharing options...
wvbansheeboy Posted January 24, 2010 Author Report Share Posted January 24, 2010 I had the same trouble with mine when I was doing the wheel bearings. What I did was get a buddy to pull on the hub as hard as he can and I used a wooden block and a little sledge hammer and just tapped on the end of the spindle while he was pulling. It actually came off pretty easily once we did that. will give it a try tomarro again thanks Quote Link to comment Share on other sites More sharing options...
