aluminum banshee frame who made it
Craig Walker
  • 7 months later...
anyone have an idea i've continued on with this bike having the steering stem lengthened several inches over factory thinking +8. the radiator i lowered inside the frame praying that i'll have enough room for pipes. now i'm running into a new unexpected issue Hardware, when the frame was made the aluminum brackets are 2 time thicker than factory and now i can't find anything chrome or stainless main killer is the upper a arm bolts, and the swing arm bolt.
http://s806.photobucket.com/home/walkerlol/index
Edited by Craig Walker
  • 4 weeks later...
Watch that sob for cracks often. I have a friend who had a all aluminum sand rail and once it started we just kept chasin um. The problem with welding aluminum is you drastically change the properties of the parent metal around the weld. the welds will hold but the pipe around it wont, hence chasing cracks, fix one another will start. I'm not saying this wont work just watch your a$$ man!
