rudy2191 Posted January 14, 2010 Report Share Posted January 14, 2010 hello everyone, i have a problem and i hope you guys can give me ideas how to solve it. i bought a banshee about 3 months ago and it ran fine. i went riding about a week ago, and a buddy of mine was using it,( i dk why i let him borrow it) and it was running fine until we heard a noise on the engine. it sounds like something scratching so we turned it off, and i fired it up again and it fires up although when i put it in gear and let go of the clutch it starts making a loud scratching noise. so we left it alone, i thought maybe it was the clutch, so today i started taking it apart, alothough when i have it on neutral and i push it, it makes that scratching noise at times it will go away then come back. so i took a look in the clutch and it seems to be okay. im killing myself here, maybe i am wrong it is the clutch or a bearing inside the engine any help would be great thankyou very much Quote Link to comment Share on other sites More sharing options...
bonerific250 Posted January 14, 2010 Report Share Posted January 14, 2010 (edited) hello everyone, i have a problem and i hope you guys can give me ideas how to solve it. i bought a banshee about 3 months ago and it ran fine. i went riding about a week ago, and a buddy of mine was using it,( i dk why i let him borrow it) and it was running fine until we heard a noise on the engine. it sounds like something scratching so we turned it off, and i fired it up again and it fires up although when i put it in gear and let go of the clutch it starts making a loud scratching noise. so we left it alone, i thought maybe it was the clutch, so today i started taking it apart, alothough when i have it on neutral and i push it, it makes that scratching noise at times it will go away then come back. so i took a look in the clutch and it seems to be okay. im killing myself here, maybe i am wrong it is the clutch or a bearing inside the engine any help would be great thankyou very much their are a number of different things that could be wrong, when you drained this oil did you notice any metal shavings in it (the will be gray in color that is normal) does it make the noise with engine at idle and not in gear? check end play of the clutch try to move it up,down side to side,check chain rollers & slide, is chain to tight,is chain oiled,if it does it at idle it could be your impeller,worse case it could be bad bearings or broken gear teeth.low gear oil could have been causing the noise. Edited January 14, 2010 by bonerific250 Quote Link to comment Share on other sites More sharing options...
Givin Em Hell Posted January 14, 2010 Report Share Posted January 14, 2010 (edited) I just got my bike running the other day. i have an overide in mine and it kept popping in and out 2nd gear. it didn't have a perfect rhythm so that was really throwing me off. After cracking the case I learned that it was a cracked shift fork. I did experience a noise that got louder as the motor revved. 1 of the screws holding the shift shaft backed out and went between my main gear on the clutch basket and crankshaft. Needed a new clutch basket. Edited January 14, 2010 by Givin Em Hell Quote Link to comment Share on other sites More sharing options...
rudy2191 Posted January 14, 2010 Author Report Share Posted January 14, 2010 their are a number of different things that could be wrong, when you drained this oil did you notice any metal shavings in it (the will be gray in color that is normal) does it make the noise with engine at idle and not in gear? check end play of the clutch try to move it up,down side to side,check chain rollers & slide, is chain to tight,is chain oiled,if it does it at idle it could be your impeller,worse case it could be bad bearings or broken gear teeth.low gear oil could have been causing the noise. i checked the oil and it doesnt have any shaving, the oil level was good in it, at idle it turns on great, when i shift to first and release the clutch,( as the bikes rolls) it makes a screaching noise, it sounds like if metal and metal are touching or so, even when it off and in neutral when i roll it, it does that noise. yea chain is oiled, chain has free play its ok, to me it sounds like the clutch bearings are gone bad but not quite sure, but this symptons go on , whether its on or off. Quote Link to comment Share on other sites More sharing options...
rudy2191 Posted January 14, 2010 Author Report Share Posted January 14, 2010 I just got my bike running the other day. i have an overide in mine and it kept popping in and out 2nd gear. it didn't have a perfect rhythm so that was really throwing me off. After cracking the case I learned that it was a cracked shift fork. I did experience a noise that got louder as the motor revved. 1 of the screws holding the shift shaft backed out and went between my main gear on the clutch basket and crankshaft. Needed a new clutch basket. ohh i see, well i rode the bike around gently, and the gears dont pop or anything, and i rev up the engine and it doesnt sound, it basically sounds as i start to drive it, like when its rolling it does the noise, whether if its on or off it does this noise. well thats great that you resolved your issue, although my clutch seems to be okay there is no wear to it thankxs Quote Link to comment Share on other sites More sharing options...
AKheathen Posted January 14, 2010 Report Share Posted January 14, 2010 is your output seal leaking at all? sounds like it may be a bad bearing on the output shaft Quote Link to comment Share on other sites More sharing options...
dajogejr Posted January 14, 2010 Report Share Posted January 14, 2010 Possible the crank is starting to split and it's rubbing. Quote Link to comment Share on other sites More sharing options...
fck55mph Posted January 14, 2010 Report Share Posted January 14, 2010 You say it makes the sound when the motor is running or cut off and when you roll it?? Put it on a stand and check your axle bearings. Sounds like that might be it Quote Link to comment Share on other sites More sharing options...
rudy2191 Posted January 14, 2010 Author Report Share Posted January 14, 2010 is your output seal leaking at all? sounds like it may be a bad bearing on the output shaft yea, thanxs everyone for the help, but i finally go it, its the output shaft bearing, when i move it with my hand, it makes the noise and it gets stuck at times thanks everyone Quote Link to comment Share on other sites More sharing options...
rudy2191 Posted January 14, 2010 Author Report Share Posted January 14, 2010 does anyone know where i can get the whole kit bearing inside the cases, like the crank and stuff thanxs Quote Link to comment Share on other sites More sharing options...
