banshee-mike Posted January 10, 2010 Report Share Posted January 10, 2010 i started my banshee after a week of sitting and it is making a ratting noise.sounds like its comming from the crank.i cant recall it making this kind of noise before.would appreciate any opinions. Quote Link to comment Share on other sites More sharing options...
00sheerzr Posted January 10, 2010 Report Share Posted January 10, 2010 i started my banshee after a week of sitting and it is making a ratting noise.sounds like its comming from the crank.i cant recall it making this kind of noise before.would appreciate any opinions. I would start by ruling out the obvious by just holding your hand over just about everything on the quad especially the kickstarter those always wear and start to rattle, does it sound like a knock or rattle? Quote Link to comment Share on other sites More sharing options...
Drewski Posted January 11, 2010 Report Share Posted January 11, 2010 well it could be a number of things But I had the same thing last summer and it turned out to be that the kick start idler gear had lost a tooth. I wish I would have pushed it back instead of riding Back, It ended up taking out the crank seal. It wouldn't hurt to have a peek. Quote Link to comment Share on other sites More sharing options...
baker Posted January 11, 2010 Report Share Posted January 11, 2010 the last banshee i had the water pump went and was making a knocking sound, u should check that also imo. Quote Link to comment Share on other sites More sharing options...
KickStartMyHeart Posted January 11, 2010 Report Share Posted January 11, 2010 Clutch noise I bet. Mine is loud and I freaked out and tore it all apart and absolutley nothing wrong with it. Quote Link to comment Share on other sites More sharing options...
banshee-mike Posted January 12, 2010 Author Report Share Posted January 12, 2010 the last banshee i had the water pump went and was making a knocking sound, u should check that also imo. how do i tell if the water pump is bad? Quote Link to comment Share on other sites More sharing options...
SAVAGE420 Posted January 12, 2010 Report Share Posted January 12, 2010 how do i tell if the water pump is bad? Take it out and look. Quote Link to comment Share on other sites More sharing options...
WINDYCITYJOHN400 Posted January 14, 2010 Report Share Posted January 14, 2010 Your going to hope for an answer that doesn't require you to split the cases.....But if the noise is "IN" the motor...That's where you need to look. You can only see so much thru the intake and exhaust openings.....Or you could try sawdust in the oil, run a nice rearend fluid in the trans and ride with an Ipod turned up. I'm sure the sound will go away if you rev it up and beat on it for a while. Start with draining the oil and checking for metal shavings..... Quote Link to comment Share on other sites More sharing options...
