hollisatp Posted January 7, 2010 Report Posted January 7, 2010 I need to get a new set of oem rings for a cr250.. i found this brand on ebay... any info on how they are?? better than oem? worse? thanks! Quote
Crazyatvspazz Posted January 7, 2010 Report Posted January 7, 2010 1st- numaura IS NOT OEM 2nd- Numara sucks from ive read...get weisco 3rd- id recommend getting a new piston AND rings ...you already have it torn down...take your cylinder to a shop get a weisco piston kit and have them bore it over.... and make sure you get all new gaskets...my .02 Quote
scottzimmerman Posted January 8, 2010 Report Posted January 8, 2010 i just put a set in my shee Ive had good luck with them in the past i put a set in my 99 kx 250 and they lasted for 5 years and they were hard years i put on it we will see how they work on the shee I'm hoping for the same results i only got about 2 hours on them in the shee the only reason i went with them is because my cylinders were still at stock bore and pistons were still good so i gust through a hone job on them and ringed it other wise i would have went weisco so Weill see if they fail and fuk my shit up ill get my 4mm set up wooo hooo that's my .02 Quote
drag+6blaster Posted September 14, 2010 Report Posted September 14, 2010 there ok pistons .. If your piston-wall clearance is good they will hold up Quote
jbooker82 Posted September 15, 2010 Report Posted September 15, 2010 You should always run the same brand of rings on the same brand of piston. If you need a ring for an OEM Piston then order it from honda. Pistons can be made up of different alloys and require different piston rings. Quote
