9banshee6 Posted January 4, 2010 Report Share Posted January 4, 2010 ok right now im using (castr927) and ( super m) but i was wondering if there's really any difference between those 2 oils cause cause carstor927 costs the double of super m but i dont really see any difference between them ? i also here yamalube it crap but can you guys tell me why? Quote Link to comment Share on other sites More sharing options...
sheerider20 Posted January 4, 2010 Report Share Posted January 4, 2010 i use ams oil dominator or i would run klotz with i think benol in it. it will give a good smell to it. i mix at 40:1 Quote Link to comment Share on other sites More sharing options...
9banshee6 Posted January 4, 2010 Author Report Share Posted January 4, 2010 i use ams oil dominator or i would run klotz with i think benol in it. it will give a good smell to it. i mix at 40:1 i thought you were supposed to mix at 32:1 Quote Link to comment Share on other sites More sharing options...
MatHolland Posted January 4, 2010 Report Share Posted January 4, 2010 I use klotz in the red and yellow jug, or the green jug. the green is the bean oil. i buy the red and yellow jug by the gallon through rmatv. i have always mixed 32:1 Quote Link to comment Share on other sites More sharing options...
06specialedition Posted January 4, 2010 Report Share Posted January 4, 2010 Do a search here on "oil" and you could read all damn day. Everyone has their on preference just like chevy, ford, dodge, toyota....... I did lots of research and ended up going with Klotz R-50. Quote Link to comment Share on other sites More sharing options...
hank 024 Posted January 4, 2010 Report Share Posted January 4, 2010 x2 on the amsoil it is good stuff would like to run it in my sled but dont know if I can use dominator and am not sure if they make a 2 stroke oil for the sleds. Quote Link to comment Share on other sites More sharing options...
Jereme6655 Posted February 7, 2010 Report Share Posted February 7, 2010 x2 on the amsoil it is good stuff would like to run it in my sled but dont know if I can use dominator and am not sure if they make a 2 stroke oil for the sleds. hank....amsoil dominator can be used in sleds......personally for my sled i run amsoil hp injector.....7800 problem free 2-stroke miles. Quote Link to comment Share on other sites More sharing options...
bansheesandrider Posted February 7, 2010 Report Share Posted February 7, 2010 i thought you were supposed to mix at 32:1 Yamaha recomends 24:1 with Yamalube and 20:1 with any thing else, but that is just covering their ass during the warranty period. If you are using a GOOD two stroke oil, itis usually recomended to go from 32 to 50:1 with some synthetics even higher. I run Klotz R50 at40:1 for over 18 years and have had zero problems. Quote Link to comment Share on other sites More sharing options...
Building my First Posted February 7, 2010 Report Share Posted February 7, 2010 Klotz R-50 or Golden Spectro. I have 6 new pints of each I won't be using. $35 shipped for the R-50, $30 shipped for the Golden. Quote Link to comment Share on other sites More sharing options...
bearhumper06 Posted February 9, 2010 Report Share Posted February 9, 2010 does the r-50 seperate in pump gas as bad as benol does? does it still have goop out the silencers? Quote Link to comment Share on other sites More sharing options...
Building my First Posted February 9, 2010 Report Share Posted February 9, 2010 The R-50 is full Synthetic, does not have ant castor in it. It's a step up from Super Techni-Plate, which has 20% castor, benol is 100% castor oil. R-50 is high rpm race oil with clean burn technology. Quote Link to comment Share on other sites More sharing options...
dajogejr Posted February 10, 2010 Report Share Posted February 10, 2010 In my opinion, the only time you need a castor based oil is if you run methanol for fuel. It stays mixed better...and methanol is corrosive, unlike gasonline...so you need the extra lubricant. For a gas motor, Super M, R50, Golden Spectro...they're all good. I personally think Amsoil is a joke for two stroke premix and gear/trans oil. But like any other oil, it has it's band of faithful....nothing wrong with that. A good mixture of 32:1 or 40:1 for a gas motor jetted and tuned properly and you'll have no oil/fuel related problems for a long time. I've never, ever heard of benoil separating in gas. The only time I've heard it separating is in very, very low temps...which Klotz even tells you. I use SuperTechniplate which has castor in it...but stays mixed at lower temps. I use it in my methanol bike and in my other gas powered engines (my mini 50cc pit bike, chain saw, weed eater, etc.) In those small motors that don't turn a lot of RPM, you don't want to mix it to rich, stay 40:1 or so. They don't turn the RPMs or build the heat to burn off the oil.... Quote Link to comment Share on other sites More sharing options...
Fast-Fibers Posted February 10, 2010 Report Share Posted February 10, 2010 I use amsoil in my drag bikes mixed at 80:1. Been running them at this mix for 3 years with no problem! My buddy is an amsoil dealer so i get a good price. Quote Link to comment Share on other sites More sharing options...
dajogejr Posted February 10, 2010 Report Share Posted February 10, 2010 My buddy is an amsoil dealer so i get a good price. That is exactly what I've found. Either your an amsoil dealer or someone's buddy is. It's like they give out dealer cost/product as often as Brittney gives you a shaved up the skirt shot...everyone's seen it.... Quote Link to comment Share on other sites More sharing options...
Fast-Fibers Posted February 10, 2010 Report Share Posted February 10, 2010 I agree that if you don't want to pay $12 a quart you need a buddy that is a dealer...........but since I run it at 80:1 I use a lot less oil. Quote Link to comment Share on other sites More sharing options...
