FMF SST
Crazyatvspazz
What is the best overall pipe. What i mean by overall is overall powergains. A pipe that doset give here but take there. my research has shown the FMF sst to be the best. input?
o and will the boysen dual stage reeds be a good compliment to the sst's?
http://www.atvsource.com/articles/product_reviews/2001/011701_sst_pipes.htm
http://www.atvsource.com/images/article_images/product_reviews/2001/ssi_pipe/fmf_dyno.jpg
wow.. your going to get ALOT of answers here...
i had .. (now on the girl friends shee).. fmf stts and they are a good overall pipe..
they have pretty good power down low.. and pull to the top pretty good..
so if your looking for a pretty good low a better mid and an alright top.. the stts are pretty good
but you will find there are a lot of "over all" powered pipes around
But what sort of power are you after? like low mid or top?
toomeys t5s are another pipe like the stts also
Ok so heres my issue i purchased a set of gnarlys. there sitting in my room still in the box lol. i was going to set it up for low/mid but as my buddy pointed out... iam only in tight wood probrably 30% of the time and the rest is all wide open fire acess roads and old logging roads. Tight woods riding is my favorite but theres not much here where i live so.... now iam thinknig of getting something thats going to give an overall power increase. When i purchased the gnarlys the assholes sent me powercore 2 sst siliencers...still sitting in the box. so iam thinking that depending on the answers i get here i may put the gnarlys on ebay and get a set of SST pipes... maybe them sending sst silencers was a sign from the banshee gods? lmao. I want something that will giv me a power increase in the woods and down those fire roads at WOT. BTW i am already patial to FMF :)
well that the riding i do..
i really liked the stts and i would go back to them they are a good overall pipe for that sort of riding style
they have enough low to pick up the wheels at low end (easy) and pull pretty good to the top
(they dont have the top of my cpis tho)
yhea i understand that there not going to be the best at every one thing...iam looking for a blend of increases if that makes sence. SOunds to me from the prompt responses (which I REALLY APPRECIATE) the ssts are what i want. Ive ordered a timing plate from chariot i was planing on setting that at +4 and i got boesen power reeds and i was planning on getting some noss cool heads 21cc domes for pump gas DOES THIS STILL SOUND GOOD? thanks guys
What do you have for pipes now?
I had SST and then went to T5's. The SST's had a little better mid and a little less top end.
If your running stock pipes now I can garuntee you will be happy with the SST's. I have to run a sparkarrestor where I ride so I ran the Turb ine Core 2 silencers.
well what you are doing is the same setup that my girls shee is (hers has boyson dual stage reeds)
and its a quick and really nice to ride shee :)
has power everywhere
:cheers::)
yhea running stock pipes. this sounds to be what iam looking for... what jetting are you running in ur gf bike? iam at a 1000 ft.
im at sea lvl pilot 27.5 air screws 1 1/4 turns mains 310
and its a k&n filter with no lid :)
its a little rich on the mains but its a girls bike :rotflmao:
what would you reccomend being at a higher elevation???
the pipes come with 270 mains and id buy 27.5 pilots
so id stick them in and do a plug chop and go from there
id say that would be around the ball park
maybe get a few sizes up on the mains to
say 280 / 290 / 300
once you get the pipes dialed in youll love them :)
well, you might want to check into t-6's before you jump strait to sst's. they are in the similar "wide band" category. i completely understand being partial to a certain brand, but don't sell yourself short and wonder for that reason.
iam well... not rich..i work at walmart to support my banshee lmao. I cant very well go buy a set of t6's then go buy a set of sst's and compare them. Thats just ridiculous. I already have silencers for the sst's. I orginally looked at the t6's but iam not a fan of punching holes in the bottom of my air box for those vents and removing my coolant reservoir. Being able to look at my coolant resiviore quickly to check the level seems important to me. idk input?
I have t6 pipes on the banshee I have now and I had another banshee a while back that had fmf sst pipes. They were fairly close as far as power goes but the toomeys look better and sound 10 times better in my opinion. To run the t6 pipes you don't have to remove the coolant resevoir or use the airbox vents, they are so little I didn't even bother using them. Since you have the silencers for the fmfs I would just try to get some used sst pipes somewhere, I don't think you will be disapointed because they were a good all around pipe.
