bonerific250 Posted December 29, 2009 Report Share Posted December 29, 2009 I live in michigan and I'm thinking of getting my head milled .020 instead of buying a "coolhead".And I was wondering who knows of a good place right close to hear that would do it and do right.And what would I need to do after I get this done as far as tuning,and would a squish band test be a good idea also.Thanks any help would be great. Quote Link to comment Share on other sites More sharing options...
SAVAGE420 Posted December 29, 2009 Report Share Posted December 29, 2009 Ive heard nothing but good things form peeps on here about Lakes Motor Sports in Waterford, Michigan http://www.lakesmotorsports.com/ And seeing how you want to keep it local. Drop by or give them a ring. I always do a squish test after any time i take my head off, then stick it back on. Hell it takes 5-10 min so why not right. Watch this so you know exactly what to do and i don't have to type it all out here Quote Link to comment Share on other sites More sharing options...
bonerific250 Posted December 29, 2009 Author Report Share Posted December 29, 2009 (edited) Ive heard nothing but good things form peeps on here about Lakes Motor Sports in Waterford, Michigan http://www.lakesmotorsports.com/ And seeing how you want to keep it local. Drop by or give them a ring. I always do a squish test after any time i take my head off, then stick it back on. Hell it takes 5-10 min so why not right. Watch this so you know exactly what to do and i don't have to type it all out here thanks for the info.and I'm not sure on how to do a squish band test,I think clearance should be no more that .030 but again I'm not sure on this.and size dia. solder should I use? f*#k missed that link, thanks again. Edited December 29, 2009 by bonerific250 Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted December 29, 2009 Report Share Posted December 29, 2009 Mull Engineering "blowit" would be a good guy to talk to. They do more than just shaving the head. They also remachine the combustion chamber. Quote Link to comment Share on other sites More sharing options...
AKheathen Posted December 29, 2009 Report Share Posted December 29, 2009 i believe he has a head exchange, too, so you can get a pre-cut head and send yours to save time....squish should be between .030 and .045 optimally, but it can run higher just fine Quote Link to comment Share on other sites More sharing options...
FASTOYS Posted December 29, 2009 Report Share Posted December 29, 2009 I live in michigan and I'm thinking of getting my head milled .020 instead of buying a "coolhead".And I was wondering who knows of a good place right close to hear that would do it and do right.And what would I need to do after I get this done as far as tuning,and would a squish band test be a good idea also.Thanks any help would be great. We also carry heads that we have shaved down .030 for a quick econimal way to boost hp. $60 outright, shipped, and no core needed!! Quote Link to comment Share on other sites More sharing options...
bonerific250 Posted December 29, 2009 Author Report Share Posted December 29, 2009 We also carry heads that we have shaved down .030 for a quick econimal way to boost hp. $60 outright, shipped, and no core needed!! thanks for all the help guys,is their anything else I should do when tuning? currently .020 wiseco pistons, k&n pods, +4 timing, fmf gnarly pipes & scileners, stage 3 dyno jet kit,stock carbs and pilots 2 turns out 340 mains 800ft elev. I ask this because I have my head off now and both cylinders have a polished look to them with a little lite scratch, and I was told polish look is normal because of thrust and lite scratches might be cylinder wash from to much gas. Ran great before putting it for the winter.thanks again. Quote Link to comment Share on other sites More sharing options...
blowit Posted December 30, 2009 Report Share Posted December 30, 2009 thanks for all the help guys,is their anything else I should do when tuning? currently .020 wiseco pistons, k&n pods, +4 timing, fmf gnarly pipes & scileners, stage 3 dyno jet kit,stock carbs and pilots 2 turns out 340 mains 800ft elev. I ask this because I have my head off now and both cylinders have a polished look to them with a little lite scratch, and I was told polish look is normal because of thrust and lite scratches might be cylinder wash from to much gas. Ran great before putting it for the winter.thanks again. No, a polished look is not what you want. polished means lack of oil retention. We add crosshatching to cylinders to increase oil retention. It would be important to hone the cylinders at a minimum (add cross hatching). Vertical stridations in the bore can be numerous things but usually comes from over heating or FOD damage. Mull Engineering Quote Link to comment Share on other sites More sharing options...
