Brewster Banshee Posted December 20, 2009 Report Share Posted December 20, 2009 What kind of performance do you pick up w/ +4 on timing plate? Is it worth it? Quote Link to comment Share on other sites More sharing options...
quikshee Posted December 20, 2009 Report Share Posted December 20, 2009 What kind of performance do you pick up w/ +4 on timing plate? Is it worth it? Most will say it's a seat of the pants difference, one of the cheapest mods you can do and one of the best. Quote Link to comment Share on other sites More sharing options...
GNR101 Posted December 20, 2009 Report Share Posted December 20, 2009 (edited) a little stronger down low... but looses alittle off the top . more power gains down low than loss off the top cheap easy mod.. worth the $60 Edited December 20, 2009 by GNR101 Quote Link to comment Share on other sites More sharing options...
AKheathen Posted December 21, 2009 Report Share Posted December 21, 2009 60?psh, you can do it cheaper, even factoring in the $12-$15 flywheel puller that you NEED.... Quote Link to comment Share on other sites More sharing options...
firebanshee Posted December 21, 2009 Report Share Posted December 21, 2009 Definitely the cheapest, and most noticeable mod you can make. You can just slot your factory plate or buy one for $35.00. Quote Link to comment Share on other sites More sharing options...
GrMeyer Posted December 22, 2009 Report Share Posted December 22, 2009 Just buy the flywheel puller and mod the stock one. It was cheap like very one said. There are some people that can get +5deg out of it but I didnt want to chance mine so I just cut to +4 and has been good to me ever sense. If my memory serves me right, there is a how two or a pic on here of a modded stock plate. Quote Link to comment Share on other sites More sharing options...
AKheathen Posted December 22, 2009 Report Share Posted December 22, 2009 and starting with +4.... Quote Link to comment Share on other sites More sharing options...
andrew3160 Posted December 22, 2009 Report Share Posted December 22, 2009 I just noticed that I have a billet timing plate on mine. Has the degrees marked in it and all and is at 0 degrees right now. Should I leave it there or advance it to +4. Will this change the reliability? I understand the basics by any info would be great, noob here. Quote Link to comment Share on other sites More sharing options...
GNR101 Posted December 22, 2009 Report Share Posted December 22, 2009 I just noticed that I have a billet timing plate on mine. Has the degrees marked in it and all and is at 0 degrees right now. Should I leave it there or advance it to +4. Will this change the reliability? I understand the basics by any info would be great, noob here. unless u have BULK comp and shitty fuel .. the reliability will be the same Quote Link to comment Share on other sites More sharing options...
FASTOYS Posted December 22, 2009 Report Share Posted December 22, 2009 What kind of performance do you pick up w/ +4 on timing plate? Is it worth it? Definetly worth it , good for about 2-3 hp across the board. Make sure to use a Banshee flywheel puller. Quote Link to comment Share on other sites More sharing options...
No Limit Powersports Posted December 22, 2009 Report Share Posted December 22, 2009 Definetly worth it , good for about 2-3 hp across the board. Make sure to use a Banshee flywheel puller. Agreed and its not just a low end gain, too much timing can be but when the right timing for your motor is found you will pick up peak hp as well. Just changing timing curves we have seen 10 hp swings on the dyno in peak power. But always remember timing and compression can cause detonationg if they are too high for your fuel. Quote Link to comment Share on other sites More sharing options...
