BOSS LX Posted December 14, 2009 Report Share Posted December 14, 2009 How much would I gain from switching from FMF gold series fattys to T5"s? I have a welded crank, +4 timing, cool head 18cc domes, and a 2-1 carb. Thanks for any help. I am mostly looking for mid to high power. Quote Link to comment Share on other sites More sharing options...
AKheathen Posted December 14, 2009 Report Share Posted December 14, 2009 what size carb you running and which 2-1 setup? you will get a different kind of power........mabey a little more, and it should come on sooner and pull real smooth. Quote Link to comment Share on other sites More sharing options...
BOSS LX Posted December 14, 2009 Author Report Share Posted December 14, 2009 what size carb you running and which 2-1 setup? you will get a different kind of power........mabey a little more, and it should come on sooner and pull real smooth. 38 mil carb Quote Link to comment Share on other sites More sharing options...
shanYE west Posted December 14, 2009 Report Share Posted December 14, 2009 You will gain maybe 1-2hp.. but both pipes are very similar in power charecteristics.. Both ramp up very quickly around 5500 rpms. But the Toomey's tend to hold peak power longer.. Once FMF's hit peak power they fall off faster then the toomey's. (this is based of a stock 350 with stock carbs) But.. Most of the time the peak HP is only within 2hp of one another. Quote Link to comment Share on other sites More sharing options...
BOSS LX Posted December 14, 2009 Author Report Share Posted December 14, 2009 You will gain maybe 1-2hp.. but both pipes are very similar in power charecteristics.. Both ramp up very quickly around 5500 rpms. But the Toomey's tend to hold peak power longer.. Once FMF's hit peak power they fall off faster then the toomey's. (this is based of a stock 350 with stock carbs) But.. Most of the time the peak HP is only within 2hp of one another. So you are saying that it is not worth the money? I thought that it may be a bigger difference. Quote Link to comment Share on other sites More sharing options...
AKheathen Posted December 15, 2009 Report Share Posted December 15, 2009 what he is saying is that it will be worth it if you find yourself coming up a little short on the top of the gear. i was also wondering which 2-1 you have because some of them don't flow verry well at higher rpm's.... Quote Link to comment Share on other sites More sharing options...
BOSS LX Posted December 15, 2009 Author Report Share Posted December 15, 2009 what he is saying is that it will be worth it if you find yourself coming up a little short on the top of the gear. i was also wondering which 2-1 you have because some of them don't flow verry well at higher rpm's.... Trinity. So you would make the switch? Quote Link to comment Share on other sites More sharing options...
papa_smurf49319 Posted December 15, 2009 Report Share Posted December 15, 2009 you will get a much better horsepower gain elsewhere, money saved on pipes could be spent better elsewhere! Quote Link to comment Share on other sites More sharing options...
RadarRacing Posted December 15, 2009 Report Share Posted December 15, 2009 I agree with what they said they would be close to the same. Those r decent pipes you have no reason to ditch those. Quote Link to comment Share on other sites More sharing options...
firebanshee Posted December 15, 2009 Report Share Posted December 15, 2009 If you want more power why not run dual carbs ? Quote Link to comment Share on other sites More sharing options...
bbcmudtruck Posted December 19, 2009 Report Share Posted December 19, 2009 I switched from FMFs to T5s and noticed very little, if any power gains. One thing I did notice though is that the T5s gave up a little bottom end. Honestly, I wouldn't switch FMF Fattys to T5s. Quote Link to comment Share on other sites More sharing options...
GNR101 Posted December 19, 2009 Report Share Posted December 19, 2009 so many ppl bash FMFs .. but there a damn good pipe Quote Link to comment Share on other sites More sharing options...
Bill Posted December 19, 2009 Report Share Posted December 19, 2009 Im running fattys on a woods ported 4mm,these pipes respond great to a good port job. Quote Link to comment Share on other sites More sharing options...
FASTOYS Posted December 21, 2009 Report Share Posted December 21, 2009 Yep Boss, Porting would be a better choice than pipe change from the sounds of it. Maybe some Dual carbs after that for more mid/top pull then a set of CPIs or Shearer pipes for even more top end depending on what your looking for. We have built some awesome bikes that were VERY fun to ride and they had stock carbs, FMFs, our porting and pump gas. Quote Link to comment Share on other sites More sharing options...
bansheemike09 Posted January 22, 2010 Report Share Posted January 22, 2010 Dual carbS AND CPEyes 2-1 aint gone git r dun. Quote Link to comment Share on other sites More sharing options...
