YamahaBanshee69 Posted December 12, 2009 Report Share Posted December 12, 2009 i have a banshee long rod 5mm 4mm stroker and im 80 over there no piston in wiseco for 100mm and i have big bore sleeve what kind of piston i can put in blaster piston ??? what i need to put some blaster piston??? thanks Paul Quote Link to comment Share on other sites More sharing options...
shanYE west Posted December 12, 2009 Report Share Posted December 12, 2009 Maybe check WSM pistons. They might have something available. Quote Link to comment Share on other sites More sharing options...
AKheathen Posted December 12, 2009 Report Share Posted December 12, 2009 you are 80 over stock, right? not 80 over the big bore sleeve? well, i'm going with theese wsm pistons http://cgi.ebay.com/ebaymotors/BANSHEE-LONG-ROD-Forged-Piston-Kit-Teflon-Coated_W0QQcmdZViewItemQQhashZitem3efafc27c1QQitemZ270498801601QQptZMotorsQ5fATVQ5fPartsQ5fAccessories they are avaliable to 66.5, then you have to go to the bb pistons starting at 68mm then to 70.5mm Quote Link to comment Share on other sites More sharing options...
dajogejr Posted December 13, 2009 Report Share Posted December 13, 2009 What size piston do you need? I'm pretty sure it's not a 100mm piston...lol. Keep in mind, banshee pistons and blaster pistons have a different dome angle, so your head/domes will have to suit. Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted December 13, 2009 Report Share Posted December 13, 2009 Yea you can run wiseco blaster pistons. That is what I ran when I had a 66mm-68mm big bore stock cylinder 4mill long rod. You will need to get a set of domes. Call up noss machine he will get you hooked up with what you need. Quote Link to comment Share on other sites More sharing options...
YamahaBanshee69 Posted December 13, 2009 Author Report Share Posted December 13, 2009 thanks for your help im gonna check that Quote Link to comment Share on other sites More sharing options...
