Replace Swing Arm Bearings Steps
FitZBanshEe
I got a 02 banshee wanted a step by step on how to replace the swing arm bearings...thanks
the pivot bearings or carrier bearings? lol
i use a long socket wrench extension to beat the pivot bearings out. put the new bearings in the freezer
and press them into the swingarm. i usually do the same with the carrier bearings. be very generous
with the grease during reassembly also.
I meant bushings...and I got the kit I need step
by step never done these before
i am not sure what bushings you are referring to other than maybe the shock linkage/dogbone?
can you post a picture of what you are tring to replace?
all the pieces in the rear end/swingarm are pretty cut and dry as far as replacement goes.
