Installed 35mm PWK
drap660
I have a 4mill stock cyl 66mm, no overide, CPI, DF3's, 17cc domes 190 compression banshee that did 105 in the 1/4 with stock carbs and 110 shortly after the 1/4. I threw in a set of 35mm PWK and didnt see much improvement but did see my gas tank go to empty 10 times faster. I guess what I am asking is, are the big carbs really worth it???? I jetted the balls out of them and got them to be perfect (no bog, straight pull through each gear). I ended up with 45pilot 152main. I am running airbox with adapters. Gearing is 16/38. Any advice will be appreciated
i would think running 1/4 on stock carbs.. would be cutting close to running bowls dry during run.. if anything the pwks would give u bigger bowls than stock :confused:
You ran 110mph with stock carbs and 16/38 gearing????
Yes. It ran 104.5 in the 1/4 and 110 top end (shortly after the 1/4). Here is a 1/4 mile pass on stock carbs (airbox on), no overide, no straps, no lockout and 16/38 gearing
The issue is, I didnt see much of a diff by adding the 35mm pwk's
Edited by drap660
  • 2 weeks later...
  • 4 weeks later...
Maybe you have reached your porting limits,your bike will spin only so much rpm no matter what carb it has.In my opinion the only way to jet for the 1/4 is make passes and check your plugs.If your chop is good your good.What are you trying to acheive?bigger carbs might not be best for your set up,ditch the air box,more air more power
what jetting were u using for the stock carbs? and what octain gas u running?
Assuming 20 inch tires, your rapping that thing up to 11,000 rpms. I'm sure the tires grow at least 2 inches, so we'll say 10,500 rpms. I guess that's possible to make power until 10,500 with stock carbs :confused: ?
Well when I went to buy tires they only had 22's (stock's are 21's)for the front but I do have 20's in the back. I also swapped my gearing to a 17/40 and got the same exact results. It doesnt lose or gain anything. The only way its gains mph is by putting a light rider on it (150lb). It picks up almost 2 miles. 107(1/4 mile)/112(top end)and this is back on stock carbs. I put the 35's to the side for now
