dekker Posted December 5, 2009 Report Share Posted December 5, 2009 Hey guys doing my build right now. Bike is going to be a duner and I will drag it for fun at silver. My motor setup will be a 4 mil drag ported stock cyl done by Wildcard Racing running Shearer's, and 34mm carbs. Wondering what you guys thing will be the best combo of hauler paddles and swinger length. I was thinking +6 with 9 or 10 paddle haulers. Any input would be helpful. Quote Link to comment Share on other sites More sharing options...
RadarRacing Posted December 6, 2009 Report Share Posted December 6, 2009 You are about right on. It depends a bit on whether you are a light rider or heavier. A +6 with 21 or 22 9 or 10 haulers or extremes would be pretty good. If you are over 200 lbs you can use a little less tire like a 9 paddle. Justabanshee has a set of 10 paddle superlites he's sellin. Quote Link to comment Share on other sites More sharing options...
jlevasseur Posted December 6, 2009 Report Share Posted December 6, 2009 I'd say you are right in the ball park. you will see very little difference with 9 to 10 paddle. might have to adjuest your gearing for the 10 depending on rider size and set up but I ran both with no issues. I noticed a little bit that in the steep tree shots the 10's would lift up a little more but I didnt mind, made treee shots more of a challenge. Good Luck ! Quote Link to comment Share on other sites More sharing options...
