carbs for hjr porting
blacksheep
I was wondering which carbs would work better for my setup. I have a HJR dune/hillshooter port and cpi inframes stock stroke. i was either going with pj34 or pwk36 a/s because i can get these pretty cheap. i know alot of guys run the pwk35 a/s but those are out of my budget right now. i also know that the air strickers are better carbs and easier to tune. would 36mm be too big? is anybody running the 36 with a similar setup if so how does it run?
Kevin could probably best answer this question for you. IMO the 36s would be too big. I run his 4 mil dune port with 35 PWKs and was running 34 TMs. I like the PWKs better but both ran well, but I have a little bigger motor.
SP
The guy that sold me the jugs was running the same setup with TM34 and he said it ran great! I guess I will try th pj's and see what happens I' ve heard they can be a B***h to get them to idle.
34 pj's will work perfect.i ran one of kev's 4mil stock cylinder drag ports and they are what i used
