MY BANSHEES BROKE!
NickisGod
ive left my 10000 dollar machine sitting under a blanket in my garage for the past 3 months because i was stumped on how i lost 75% of my cubs power overnight. i had once assumed it was my stator, then my ignition coil, then i thought maybe my reeds have prematurely failed. all of these turned up negative. then i though maybe i have a bad batch of gas, or maybe a choke was stuck open. i checked my compression changed my plugs and then walked away for 3 months untill i returned to the bike to tackle the issue once agian. at this point i checked everything twice besides my carbs and noticed one pipe was hotter than the other. i pulled of the carb that seemed to be causing the issue to discover a piece or paper towel made its way down into my float bowls clogging my main jet. about the size of my pinky nail this sucker fell right out as soon as the float bowl was removed.
i guess the moral of the story is dont give up, just take a brake. but more or less i wanted to share this story with the forums because im sure this isnt the first time this is happened and no expert can give you advice on an oversight. yup a papper towel......live and learn
well i have exposed air filters and i was giving her a bath so i stuffed my carbs with papper towels so i didnt get any water into my engine...... wat a headache.
I dont know what kind of carbs you have but, with the pwks, a 2" rubber pipe cap with hose clamp fits perfect over the carbs when
removing the air filters for storage and cleaning. :cheers:
I DONT BELIEVE IT!!!!!
I would if I had positive proof. Perhaps a pic of your girl holding said paper towel.
J/K I do really crazy stupid shit too. When I figure out what I did i am usually truly amazed I have lived as long as I have, being that I am a moron and all.
:confused:
