YFZ tie rods or banshee rods
BOOZER2009
I would get the +2's or you could do the same thing I did and get a set of Grizzly 700 rods and ends. they are beefy and you can find them for dirt cheap
Right on. Thanks for the info once again. I think I found a complete 07 set up as well ( spindle hubs brakes etc..). I don't remember, did you use the 450 stock shocks? I am thinking of using the suzuki ltr shocks at 17.25" which if I understand correctly bring me back up to stock height. Trying to do this on a budget. Can't afford pricey shocks
yes the ltr shocks will bring it closer to stoke height.........make sure if you get the grizzly rods, you use the ends also. the inside threads are different than the banshee
Right on. Thanks again. I'll shoot some picsonce I ge this frame coated and start installing
The yfz rods will work but there isn't much thread holding them on, alot of people feel safer about going with the banshee +2.
Makes sense. I could see those getting pulled out possibly. FYI I actually found arms, spindles, hubs, complete brake system brand new never used off an 07. Selling for a decent price. So I may pick that up. But good luck on selling your stuff.
what manufacturer makes the grizzy? Where did you pick yours up? Ebay? or any specific grizzly forum? Is the grizzly route cheaper then having the stock ones modified? Or iois that even possible?
well you can find them on ebay or you can get them new at ALLBALLZ. they sell the hole kit with the rods and ends
