Ieat4strokes Posted November 29, 2009 Report Share Posted November 29, 2009 On a 4 mill drag ported FAST motor where should I start with gearing on 300 ft dirt drags? I'm gonna be running a 8 inch arm with pro wedges in soft dirt clay like in sig pic. I'm around 190 lbs. Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted November 29, 2009 Report Share Posted November 29, 2009 What tranny set-up do you run,1-4 pull I ran 15-39 but im set up for asphault with my straight cuts.I also ran a wheelie bar,screwed tires,lockout w/stiff tune Quote Link to comment Share on other sites More sharing options...
J-Madd Posted November 29, 2009 Report Share Posted November 29, 2009 15/42 works pretty good. Quote Link to comment Share on other sites More sharing options...
Ieat4strokes Posted November 30, 2009 Author Report Share Posted November 30, 2009 I'm still on stock tranny don't worry that's next but Jeff nodded the he'll out of it it shifts like butter. Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted November 30, 2009 Report Share Posted November 30, 2009 Your bike will feel like it doubled hp with the tranny ,good luck Quote Link to comment Share on other sites More sharing options...
AWR Posted January 12, 2010 Report Share Posted January 12, 2010 On a 4 mill drag ported FAST motor where should I start with gearing on 300 ft dirt drags? I'm gonna be running a 8 inch arm with pro wedges in soft dirt clay like in sig pic. I'm around 190 lbs. the dirt you are running on in your sig looks identical to what we race on here.i ran between 14-40 and 14-42 with pro wedges but never had any luck with an 8 inch swinger.ended up with a 4 inch swing arm and 65inch wheelie bar.my tranny was uncut also but i cut 3 dogs off 3 thru 5.left in 2nd finish in 5th.was unbeaten in my class for 2 yrs with that combo(350 mod-any chassis,any fuel,no cut trannies,no aftermarket cylinders).at that time i weighed around 230....good luck Quote Link to comment Share on other sites More sharing options...
BigRed350x Posted January 20, 2010 Report Share Posted January 20, 2010 No one can give you a good suggestion without knowing what ratio your primary's are. Do you have straight-cuts? If you do, then what ratio are your primary gears? It changes quite a bit when your primary gears change. Firehead custom made my straight-cuts and they sit at a 3.28 ratio which is stupid tall. I run 14x45 on my 10mil for 300ft with a 22" 14 paddle extreme. Quote Link to comment Share on other sites More sharing options...
J-Madd Posted January 20, 2010 Report Share Posted January 20, 2010 Safe to say he's running stock primary gears. I doubt he would spend $350 (or whatever straight cut high ratio gears cost) before he bought an override, but I could be wrong Quote Link to comment Share on other sites More sharing options...
J-Madd Posted January 20, 2010 Report Share Posted January 20, 2010 No one can give you a good suggestion without knowing what ratio your primary's are. Do you have straight-cuts? If you do, then what ratio are your primary gears? It changes quite a bit when your primary gears change. Firehead custom made my straight-cuts and they sit at a 3.28 ratio which is stupid tall. I run 14x45 on my 10mil for 300ft with a 22" 14 paddle extreme. What r/o tire do you have? What is your 60 ft times? Man my Cub blows 72 r/o 14 pdl extremes off all the way down the track with me on it (185 lbs). I don't see how you can get that thing down the track with those tires unless they are 80+ r/o!! Quote Link to comment Share on other sites More sharing options...
Ieat4strokes Posted January 21, 2010 Author Report Share Posted January 21, 2010 Yea I hop i didnt go too long on the arm, i know in the yard she blows the tires all the way across my backyard, prolly a good 300ft. Have to wait and see how she does at the track, i have wedges and paddles to try. No one can give you a good suggestion without knowing what ratio your primary's are. Do you have straight-cuts? If you do, then what ratio are your primary gears? It changes quite a bit when your primary gears change. Firehead custom made my straight-cuts and they sit at a 3.28 ratio which is stupid tall. I run 14x45 on my 10mil for 300ft with a 22" 14 paddle extreme. Primarys are stock, havent gone full all out drag as of yet, i still ride it "recreationally" as well, comp here isnt that stiff to ONLY drag it...lol Safe to say he's running stock primary gears. I doubt he would spend $350 (or whatever straight cut high ratio gears cost) before he bought an override, but I could be wrong No need for confusion J, your correct. Quote Link to comment Share on other sites More sharing options...
tundish2800 Posted January 24, 2010 Report Share Posted January 24, 2010 I ran 14/41 on a stock cylinder 4mil. The bike weighs 350 and i weigh 245 i was running 4.83@68mph spinning the whole way down the track. I only had ten paddles on last year this year i have 12 paddles. Quote Link to comment Share on other sites More sharing options...
Ieat4strokes Posted January 25, 2010 Author Report Share Posted January 25, 2010 Thanks. I think Ima need more paddle ad well. I have wedges and 10 paddle extremes. Quote Link to comment Share on other sites More sharing options...
firebanshee Posted January 26, 2010 Report Share Posted January 26, 2010 15/42 works pretty good. X-2 Quote Link to comment Share on other sites More sharing options...
brave&crazy racing Posted February 2, 2010 Report Share Posted February 2, 2010 try 15 45 to 15 47 leave in 2 works on my 4 mill stocker by a&s with pw1. i am 175 Quote Link to comment Share on other sites More sharing options...
Ieat4strokes Posted February 5, 2010 Author Report Share Posted February 5, 2010 thanks fellas.....appreciate it Quote Link to comment Share on other sites More sharing options...
