wannashee20 Posted November 24, 2009 Report Share Posted November 24, 2009 Ok so I got my banshee last summer and it has never run quite right and we have been tinkering around with it the whole time. I dont know what the jetting on my carbs is, but i have PWK 28's. We noticed the reed spacers were turned around so we put them back the way they are supposed to be, plugged the carbs because they were just sucking air (and whatever else) through them, put an air box filter set up with out the lid on it, and changed out the gas tank because the other one had a hole in it. It started up just fine and idled for about 2 or 3 minutes no problem then all of a sudden it quit! We flipped the reed spacers back to the way they were and that wasnt the touchy issue, the plugs were getting spark but it was weak so we changed those, compression is at 120 each side. Anyone got any suggestions I would love some help! Its about to get snowy here and i want it running before i put it away. Thanks everyone! Quote Link to comment Share on other sites More sharing options...
Ruko Posted November 24, 2009 Report Share Posted November 24, 2009 The 3 main things needed for a 2 stroke to run are compression, spark and fuel. If you have compression and you have spark then make sure you are getting fuel. If you just put a new fuel tank on maybe it had some crap in it. I don't know what you mean by "plugged the carbs" but I would pull them apart and make sure they are clean, and check the screen in the petcock. Also if you were switching the reed spacers from one side of the reeds to the other that shouldn't make any difference. I have seen them on either side. Quote Link to comment Share on other sites More sharing options...
wannashee20 Posted November 24, 2009 Author Report Share Posted November 24, 2009 I am sure that I am getting fuel, and i mean that the nipple(dont know what its called) on the back top of the carbs was just open and sucking in air and all the dust into the carb so I plugged it on both. I dont know if that is throwing it off or not. I will have to go back over the carbs and re clean them, but i did that right before i put the air box on. Thanks for the ideas! Quote Link to comment Share on other sites More sharing options...
Ruko Posted November 25, 2009 Report Share Posted November 25, 2009 Hmmm that nipple may have been a vent. They usually have a hose on them that runs down below the carb, but they are left open. If you plugged it off it may be causing a vacuum inside, like trying to pour out of a fuel can without opening the vent. Try unplugging it and see what happens. Quote Link to comment Share on other sites More sharing options...
papa_smurf49319 Posted November 25, 2009 Report Share Posted November 25, 2009 i think the nipple that she is talking about i drilled right into the carb body, i might be able to find a pic. The one up top next to the choke? Quote Link to comment Share on other sites More sharing options...
Ruko Posted November 25, 2009 Report Share Posted November 25, 2009 So does that vent hose come off it or is it from somewhere else?? It is hard to tell from that pic. I have Mikuni's on mine so I don't know for sure how the Keihin's are set up. I know lots of people use those carbs so maybe someone with them can help out. Quote Link to comment Share on other sites More sharing options...
papa_smurf49319 Posted November 25, 2009 Report Share Posted November 25, 2009 im not to familiar with the 28's but i think i remeber someone saying those were for oil injection but i could be wrong. Quote Link to comment Share on other sites More sharing options...
wannashee20 Posted November 25, 2009 Author Report Share Posted November 25, 2009 Thanks for the help Ruko I will try unplugging it and see what happens. Quote Link to comment Share on other sites More sharing options...
papa_smurf49319 Posted November 25, 2009 Report Share Posted November 25, 2009 I wouldnt unplug it you will be sucking dirt and extra air threw that plug Quote Link to comment Share on other sites More sharing options...
wannashee20 Posted November 25, 2009 Author Report Share Posted November 25, 2009 well i am going to try it cody, after we figure out whether or not that is the problem we can go from there on what we need to do in order for it not to suck in all the dirt. Quote Link to comment Share on other sites More sharing options...
papa_smurf49319 Posted December 12, 2009 Report Share Posted December 12, 2009 (edited) Anybody else have these on the 28 pwks? Ive only seen a few sets with them? The nipple is drilled right into the carb body, just seems like if left unplugged it would run super lean and suck dirt! Edited December 12, 2009 by papa_smurf49319 Quote Link to comment Share on other sites More sharing options...
papa_smurf49319 Posted December 13, 2009 Report Share Posted December 13, 2009 nobody knows? Quote Link to comment Share on other sites More sharing options...
papa_smurf49319 Posted December 14, 2009 Report Share Posted December 14, 2009 bumpy Quote Link to comment Share on other sites More sharing options...
papa_smurf49319 Posted December 17, 2009 Report Share Posted December 17, 2009 bump Quote Link to comment Share on other sites More sharing options...
