fourxquad Posted November 24, 2009 Report Share Posted November 24, 2009 Hey guys I just broke a ring in my motor, So im trying to figure out what i should do to it. I don't want to pull the crank out at this time.. I'm thinking about just putting a set of cylinders and pistons in it and change the head out. Just wanted to get some ideas on what way to go and what parts to stay away from. This bike only runs in the sand dunes.. Thanks for the help... Quote Link to comment Share on other sites More sharing options...
TwistedSheeRida Posted November 24, 2009 Report Share Posted November 24, 2009 Cheetah Cubs, noss head, 35 pwks or bigger, vforce reeds, shearers or cpi inframes, shift star mod, shaft mod, and shift pro kit if you feel it necessary, and a +4 swingarm or so. thats my .02 lets hear some more imput Quote Link to comment Share on other sites More sharing options...
kodie Posted November 24, 2009 Report Share Posted November 24, 2009 skys the limit on mods only thing that stops mods is how deep the wallet is. How much you got to spend and what is done to it now? Quote Link to comment Share on other sites More sharing options...
fourxquad Posted November 24, 2009 Author Report Share Posted November 24, 2009 skys the limit on mods only thing that stops mods is how deep the wallet is. How much you got to spend and what is done to it now? The money part is not a big issue, I just want something that is going to be reliable and fast im tired of being beat up the hill by 4 strokes.LOL Im a bigger guy so i need to beef if up. It has Toomey T5 exhaust on it, boost bottle, took out the air box and added kn's, timing advanced... The motor is all stock. i bought the bike brand new in 06 its a limited edition and it had all the exercisers on it, It also has a plus 4 swing arm.. Quote Link to comment Share on other sites More sharing options...
Stirling 421 Posted November 24, 2009 Report Share Posted November 24, 2009 The money part is not a big issue, I just want something that is going to be reliable and fast im tired of being beat up the hill by 4 strokes.LOL Im a bigger guy so i need to beef if up. It has Toomey T5 exhaust on it, boost bottle, took out the air box and added kn's, timing advanced... The motor is all stock. i bought the bike brand new in 06 its a limited edition and it had all the exercisers on it, It also has a plus 4 swing arm.. i put a 421 cheetah in my bike that will beat those 450s. still good for duning too Quote Link to comment Share on other sites More sharing options...
kodie Posted November 24, 2009 Report Share Posted November 24, 2009 either send your cylinders to kevin her from herr juggs racing or send them to jeff at farmandsandtoys and get them ported or like said before buy some cheetah cylinders they are the site sponsors and they do incredible work and porting is the cheapest mod for the most power. and then get ya a cool head with some 20 cc domes unless you want to run race fuel then get ya like some 18cc domes this will bump your compresion up and wake her up. I've used both chariot and noss heads they are both great peices and i would recomend either one. vforce 3 reeds also play around with the gearing on your sprockets the lower you go in the front the more low end she will have but it will also take some of the top end away and vice versa. Quote Link to comment Share on other sites More sharing options...
fourxquad Posted November 25, 2009 Author Report Share Posted November 25, 2009 either send your cylinders to kevin her from herr juggs racing or send them to jeff at farmandsandtoys and get them ported or like said before buy some cheetah cylinders they are the site sponsors and they do incredible work and porting is the cheapest mod for the most power. and then get ya a cool head with some 20 cc domes unless you want to run race fuel then get ya like some 18cc domes this will bump your compresion up and wake her up. I've used both chariot and noss heads they are both great peices and i would recomend either one. vforce 3 reeds also play around with the gearing on your sprockets the lower you go in the front the more low end she will have but it will also take some of the top end away and vice versa. Thanks for the great info guys... Quote Link to comment Share on other sites More sharing options...
AKheathen Posted November 25, 2009 Report Share Posted November 25, 2009 how bad are the cylinders after breaking the ring? most likely just nicked the port and there is probably plenty left that will be removed anyway with porting.... Quote Link to comment Share on other sites More sharing options...
SonOfSand Posted November 25, 2009 Report Share Posted November 25, 2009 Hey guys I just broke a ring in my motor, So im trying to figure out what i should do to it. I don't want to pull the crank out at this time.. I'm thinking about just putting a set of cylinders and pistons in it and change the head out. Just wanted to get some ideas on what way to go and what parts to stay away from. This bike only runs in the sand dunes.. Thanks for the help... From what I have been told, if you are thinking about getting the cylinders ported, or even better, going to a cub, you need to reinforce the crank, otherwise, you are prone to losing the crank. So, if reliability is a priority, you need to consider reinforcing the crank. I just went through all of this, and I am glad I have the peace of mind with a hot rods crank. I just did the mods below, and the only four strokes that beat me are purpose built Raptors, and 450's on the bottle. Quote Link to comment Share on other sites More sharing options...
