Part out!
  • Replies 46
  • Created
  • Last Reply
Top Posters In This Topic
This is a revised list of what I still need to get rid of. I also forgot to add that the parts are located just outside of clio, michigan. If you wanna come pick up some stuff up your welcome too.
Cylinders stock port/bore (had 110compression on both sides) - 240 Shipped
Crank - 115
Cases (No chain whack) - 140
Head (no pitting) - 25 Shipped
FMF powercore 2 silencers - 75
Flywheel - 75 Shipped
YFZ450 spindles - 65 shipped
YFZ450 hubs - 45 Shipped
CDI - 51 Shipped
Coil - 26 Shipped
Rear axle carrier - 40 Shipped
Gas tank - 15
Shift lever -15 Shipped
Tranny (Includes gear packs, shift drum, and forks) - 145 Shipped
Seat - 55
Head lights - 65 shipped
Clutch pack - 85 Shipped
Thumb throttle - 25 Shipped
Radiator - 32 Shipped
Rear shock (yellow spring) - 68 Shipped
Killswitch - 28 Shipped
Rear sprocket hub w/41 tooth - 28 Shipped
Swingarm - 25
Grab Bar - 21 shipped
Frame (Have title in hand) - 250 Would prefer local pick up
Handlebars - 34 Shipped
Rear caliper w almost new pads and b/o plate - 70 Shipped
Fullflight +2 silvervein tie rods - 30 Shipped
ModQuad Polished grill (Almost New) - 30 Shipped
6 HD clutch springs - 25 Shipped
Modified shift shaft - 20 Shipped
Kicker gear - 20 Shipped
Dogbone w/linkage - 20 Shipped
Axle nuts - 10 Shipped
13t front sprocket - 12 Shipped
Stock clutch cover w/billet insert and waterpump - 40 Shipped
Swingarm bolt - 15 Shipped
Edited by quikshee
