busaboy Posted November 12, 2009 Report Share Posted November 12, 2009 ok im new... names waylon need some help i just bought a 1989 banshee and it needs exhaust o rings.. i went and bought the fmf o-rings and springs and the o rings are to big.. is there differnt sizes? they said 1 size fits all lol.... will just any o ring work?like form home depo that will fit? what about high temp rtv silicone? it has paul turner headers.. thanks any help Quote Link to comment Share on other sites More sharing options...
AKheathen Posted November 12, 2009 Report Share Posted November 12, 2009 clean all the crap out of the o-ring grooves first, then lube it with spit and install with pressure Quote Link to comment Share on other sites More sharing options...
crustydemon Posted November 12, 2009 Report Share Posted November 12, 2009 Paul turners dont have o ring grooves, at least the ones I have had didnt. Quote Link to comment Share on other sites More sharing options...
busaboy Posted November 12, 2009 Author Report Share Posted November 12, 2009 they are puking oil and smoke out of them... theres a little lip where they would butt against the Cylinder head looks like thats where a o ring would go just taking a guess tho as i dont have a clue... i bought the fmf o rings and spring kit but the o ring is like 1/4 to big..can i just use a high temp silicone and slide the expansion chambers back on? would it seal it? Quote Link to comment Share on other sites More sharing options...
papa_smurf49319 Posted November 12, 2009 Report Share Posted November 12, 2009 Some pipes are just slip on and you use high temp silicon and just slid them over the cylinder, dont get to crazy on the high temp though. Other pipes such as the stockers have a groove in the pipe flange itself, this is where the oring goes. To me it sound like you were trying to install the orings on the cylinders themself, maybe i just misunderstood you. Also i do know that paul turners have a spot for orings on the head pipes, maybe the older sets did not? Cody Quote Link to comment Share on other sites More sharing options...
busaboy Posted November 12, 2009 Author Report Share Posted November 12, 2009 ok thanks it doesnt look like a o ring would go in there i will just use high temp silicone thanks Quote Link to comment Share on other sites More sharing options...
99bansheeboy Posted November 12, 2009 Report Share Posted November 12, 2009 make sure you remember to change your muffler bearing as well while your in there Quote Link to comment Share on other sites More sharing options...
busaboy Posted November 13, 2009 Author Report Share Posted November 13, 2009 ya the bearing was bad also and it was low on blinker fluid so i topped that off also make sure you remember to change your muffler bearing as well while your in there Quote Link to comment Share on other sites More sharing options...
Hellbroke Posted May 16, 2014 Report Share Posted May 16, 2014 is this how the o ring should sit? Sent from my Nexus 4 using Tapatalk Quote Link to comment Share on other sites More sharing options...
Vicstuff Posted May 16, 2014 Report Share Posted May 16, 2014 Should go in a groove in the pipe at least that's how my pcs are and my toomeys were 1 Quote Link to comment Share on other sites More sharing options...
5150banshee Posted May 16, 2014 Report Share Posted May 16, 2014 Should go in a groove in the pipe at least that's how my pcs are and my toomeys were same here there is a groove on my shearer the o ring sits in. Sent using Iphone5 onTapatalk Quote Link to comment Share on other sites More sharing options...
5150banshee Posted May 16, 2014 Report Share Posted May 16, 2014 i did it both ways, one in the pipe groove, then one like that. what side worked better ?? Sent using Iphone5 onTapatalk Quote Link to comment Share on other sites More sharing options...
5150banshee Posted May 16, 2014 Report Share Posted May 16, 2014 no idea. I have an o-ring in the groove then and o-ring on the flange on both side, used 4 o-rings total.gotcha Sent using Iphone5 onTapatalk Quote Link to comment Share on other sites More sharing options...
Hellbroke Posted May 16, 2014 Report Share Posted May 16, 2014 I only got two 0 rings and 4 springs with the FMF kit I bought and they couldn't fit in the pipe and they just slipped on the cylinder so I don't know where else they would go. I have gold series on my bike. Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted May 19, 2014 Report Share Posted May 19, 2014 How old are the pipes? Quote Link to comment Share on other sites More sharing options...
