what jets for a 4 mill engine?
SUPERJETRUSS
I have a HJR 4 mill stroker I just built, NOSS head that has pump/race gas 21cc domes, Ported cylinders by Kevin dont know what port job I think it might be MX but also ported for T5's, Chariot reeds with Chariot billet intake with built in crossover, and my timing set at 4 degrees, and toomey T5 pipes. What jets do you recommend for stock carbs with the tors removed on this setup? MY elevation is around 850 ft.
Not to be a jerk,but call Kevin.He can set you up on your needs.I think he is on vacation this weekend at Glamis.You can try his number and just maybe he will answer his cell ph.Good luck though.
The only thing that would help alot is exhaust duration #s,most of the shit I wrote down with durations instead of port type,Go rich first see how she feels.If its fresh do a couple of heat cycles with the 360s take it for a rip see how it feels,just dont string it out if its a new build ,let her break in then tune it.You can go crazy jetting b4 the rings are seated properly,plus I baby new motors
THANKS!! for all the help!!!
  • 2 weeks later...
so what did u come up with, i also have a hjr duner hillshooter ported motor, 4 mil long rod, high compression for 110oct like 18cc, vf3 reeds, t5's and stock carbs with pods. i was told to go 330 or 340 if wanted to be safe and thats at the imperial sand dunes(oh and pilot could stay stock 25). well 340 was rediculous lean and throttle was not snappy< low end bogged. went to 27.5 pilots 1 1/2 turns out on mixture screw and main to 360. throttle snappy now and no more boggin, but main still lean looks like could go to 380 atleast. i just did a pull today in phoenix with brand new plugs that i put in after warm up and shut down while runnin wide open so i know i got a good read.
curious to see what u had come up with
What air filter system are you running and how did the suggestion work out. with pods you usually go up 2 jet size's on the mains. Also what needles are you using stock or aftermarket.
im using stock needles which I just raised it up one notch and go pilot jets im using a 27.5 and main jet Im using a 320. ran it and Im still a little lean so Im going to jump up to a 340 main and see how that works out and Im running pods on my setup I ditched the stock air box. the only thing is its a bear to start Even choked I have to take off a pod and stick my hand over the carb to get it popping, as soon as it warms up it starts right up, what the deal with this? And who make aftermarket needles and are they better than stock?
Your hard cold start is because it's too lean. Either turn the air mixture screws in some, or go bigger on the pilot.
I think I definitly need to go to a bigger pilot jet for sure! It actually runs half way decent with it turned about a 1/4 way out what do you guys recommend for my pilot size I have a 27.5 now should I step up to a 30? and is the plastic piece that slides over the main jet nesacary I was thinking about removing mine if there not needed
Step up to a 30 pilot, and leave the plastic piece in. It helps keep the fuel from sloshing away from the jets.
