505chevelle Posted November 4, 2009 Report Share Posted November 4, 2009 When running two fogger nozzles on gasoline, what jet spread are you guys using to get a clean plug? What are you doing with timing? I have a lot of experience with nitrous in racecars, but will be my first time spraying on the banshee. Any help??? Quote Link to comment Share on other sites More sharing options...
bigboybanshee Posted November 4, 2009 Report Share Posted November 4, 2009 If I remember correctly, it's a 4 jet spread for gas, 8 jet spread for methanol. On timing, 20 shot (total) or less, leave the timing the same as you would an all engine pass. Every 10 more hp you go up after 20, retard the timing 1 degree. (i.e. 30 shot - retard 1 degree, 40 shot - 2 degrees, and so on...) This was how I ran mine and it worked great. The recommendations I received came straight from nitrous express. Quote Link to comment Share on other sites More sharing options...
captainhowdie Posted November 4, 2009 Report Share Posted November 4, 2009 Not to ruin your thread, but i am wanting to throw a bottle on my 421 cub. What is the cheapest/ easiest way to throw a kit together? I have no experience with nitrous at all so i need a list of al the parts needed. Any help would be awsome! Quote Link to comment Share on other sites More sharing options...
505chevelle Posted November 4, 2009 Author Report Share Posted November 4, 2009 Not to ruin your thread, but i am wanting to throw a bottle on my 421 cub. What is the cheapest/ easiest way to throw a kit together? I have no experience with nitrous at all so i need a list of al the parts needed. Any help would be awsome! The cheapest way I have seen, If you are starting with nothing, is to buy a twin cylinder kit from Dynotune nitrous. We have used these kits on YFZ450's and 700 raptor's with great success. Single nozzle kit of course on those. I am going to use some spare solenoids from my car stuff and a couple of NOS stainless nozzles, buy a pump and bottle from Dyno tune, already bought a rectifier/regulator to charge a battery and hook it all up with a arm switch and a full throttle switch. Here is a link to the twin cylinder kit from Dyno tune... My link Quote Link to comment Share on other sites More sharing options...
bigboybanshee Posted November 4, 2009 Report Share Posted November 4, 2009 Not to ruin your thread, but i am wanting to throw a bottle on my 421 cub. What is the cheapest/ easiest way to throw a kit together? I have no experience with nitrous at all so i need a list of al the parts needed. Any help would be awsome! Pick up a kit, it's cheapest that way. If you piece it together, you'll spend more on individual parts, assuming you're buying new. I highly recommend getting a fuel safety switch to go with your kit, a purge kit is also a good investment IMO Before spraying your bike, I highly recommend talking to someone who is familiar with nitrous and what to expect...it can be a blast in a good way or bad, really quick, LOL Quote Link to comment Share on other sites More sharing options...
93turbolx Posted November 15, 2009 Report Share Posted November 15, 2009 What kind of fuel pressures are you starting at with a 4 jet spread? I assume on this stuff you leave the F.P. and change the spead because of no regulator? Chris, let me know how you end up with your tune-up and how it works out! Kinda interesting to say the least. Quote Link to comment Share on other sites More sharing options...
505chevelle Posted November 16, 2009 Author Report Share Posted November 16, 2009 What kind of fuel pressures are you starting at with a 4 jet spread? I assume on this stuff you leave the F.P. and change the spead because of no regulator? Chris, let me know how you end up with your tune-up and how it works out! Kinda interesting to say the least. Will do Justin, Everythings coming along good. Got everything mounted up tonight. I plan on flowing the fuel out of the pump, to see what pressure it has, then jet accordingly. The pump is rated to 4-7 psi. I hope to have it done in the next few days and makes some hits on it. Quote Link to comment Share on other sites More sharing options...
lt1bird Posted November 24, 2009 Report Share Posted November 24, 2009 http://www.dynotunenitrous.com/store/scripts/prodView.asp?idproduct=174 kit jetting should be same... #12/#12 based on 5-6PSI See installation Instructions here>>>> http://www.dynotunenitrous.com/store/INSTRUCTIONS/NITROUS%20KIT%20DIRECT%20PORT%20BIKES.pdf Quote Link to comment Share on other sites More sharing options...
