painting banshee pipes?
will fox
i use bar B-Q grill paint skuff up the pipe lightly with sandpaper then warm it up real good with a torch or somthing get it hot not so hot that you cant touch it but almost then spray it do like 3 coats after it drys real good it looks all dull duff it up with a soft cloth and it will shine up nicely goodluck man :cheers:
i have a set of t-5 and painted them several times. the problem was that paint did not hold up well i have tried header, engine, and gril paint with the same results. it would look good for a while but would not hold up for very long and if the pressure washer got close to it the paint would come off. so i found some high temp powdercoat on www.eastwood.com this has been on my pipes for over 2 years with no problems.
  • 2 years later...
