armybanshee Posted October 31, 2009 Report Share Posted October 31, 2009 NEED HELP!!!!!!, BANSHEE WILL START NORMAL BUT WHEN STARTING TO PUSH THROTTLE COMES TO A POINT THAT IT WOULD NOT GO ANY HIGHER IN RPMS. IT IS FINE TO A POINT BUT AFTER THAT IT SEEMS LIKE ITS FULL OF FUEL OR NOT ENOUGH AIR. CAN NOT FIGURE OUT Quote Link to comment Share on other sites More sharing options...
banshee-mike Posted October 31, 2009 Report Share Posted October 31, 2009 NEED HELP!!!!!!, BANSHEE WILL START NORMAL BUT WHEN STARTING TO PUSH THROTTLE COMES TO A POINT THAT IT WOULD NOT GO ANY HIGHER IN RPMS. IT IS FINE TO A POINT BUT AFTER THAT IT SEEMS LIKE ITS FULL OF FUEL OR NOT ENOUGH AIR. CAN NOT FIGURE OUT does it sound like it is hitting a rev limiter?if it does,try pusing in on the wire that goes to the parking brake on the clutch lever. Quote Link to comment Share on other sites More sharing options...
armybanshee Posted November 3, 2009 Author Report Share Posted November 3, 2009 does it sound like it is hitting a rev limiter?if it does,try pusing in on the wire that goes to the parking brake on the clutch lever. DUDE THANK YOU SO MCH IT FIXED MY PROBLEM, AGAIN THANK YOU!!!!!!!!!! Quote Link to comment Share on other sites More sharing options...
