SUPERJETRUSS Posted October 30, 2009 Report Share Posted October 30, 2009 Is the stock clutch basket suppose to move back and forth if you hold the primary gear and grab the basket and spin it back and forth, if so how much movement is considered fine? Im putting together a 4 mill and I dont want the basket to gernade, thanks guys Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted October 30, 2009 Report Share Posted October 30, 2009 No it is not. The coushins inside the basket are shot. Your best bet is to get an aftermarket billit basket. It will come with new coushins. You will have to grind the rivits off that hold the pirmary gear on the oem basket. Then you will put that gear with new coushins on the billit basket. Look at the sticky above for the stock to billit basket swap. josh Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted October 30, 2009 Report Share Posted October 30, 2009 Here is the link http://bansheehq.com/forums/index.php?showtopic=85373 You can see how the black oem coushins are loose and worn out in the pic vs the new red ones that fit tight. josh Quote Link to comment Share on other sites More sharing options...
SUPERJETRUSS Posted October 31, 2009 Author Report Share Posted October 31, 2009 alright now that that's settled whats a good clutch basket to go with are the magnums that f.a.s.t sells any good or should i go with like a wiseco or hinson? Quote Link to comment Share on other sites More sharing options...
blowit Posted October 31, 2009 Report Share Posted October 31, 2009 Is the stock clutch basket suppose to move back and forth if you hold the primary gear and grab the basket and spin it back and forth, if so how much movement is considered fine? Im putting together a 4 mill and I dont want the basket to gernade, thanks guys It would be a good ideal to inspect the basket well for wear. Specifically grooving of the drive ears on the outside. Usually when the cushions get worn, it causes accelerated wear on the basket. That will cause clutch sticking and poor shifting. If you are not familiar with these issues, simply search the site. There is a ton of info around on the subject. Quote Link to comment Share on other sites More sharing options...
SUPERJETRUSS Posted October 31, 2009 Author Report Share Posted October 31, 2009 Just ordered the MAGNUM BASKET and the FAST clutch kit from Jeff!! Awesome customer service cant wait to get it in and intall it!! thanks for all the help on this topic!!! Quote Link to comment Share on other sites More sharing options...
