AKheathen Posted January 20, 2010 Report Share Posted January 20, 2010 well, it will probably be between dune and drag somewhere. another thing i don't like about them is that it throws the squish band off, and only on one side. this could end up being a really bad thing, especially as the bore wears and piston rock really increases Quote Link to comment Share on other sites More sharing options...
BANSHEE HP Posted January 20, 2010 Report Share Posted January 20, 2010 it doesnt matter whos or what piston it is in a loose/ wore out bore...its going to be bad. the cut on the piston is like 1-1.5mm and only as wide as a stock exhaust port. Quote Link to comment Share on other sites More sharing options...
AKheathen Posted January 20, 2010 Report Share Posted January 20, 2010 what i'm getting at is that it is uneven pressure on the piston when it's at it's most strain. think of it like this- put a donut spare on a truck with 35's and go muddin.........it won't handle verry good, or make it as far......aside from that, the uneven squish will effect the burn and may increase spark blow-out Quote Link to comment Share on other sites More sharing options...
