peanut2 Posted October 26, 2009 Report Share Posted October 26, 2009 I just bought a bad ass banshee that has alot of mods done to it cheetah supercub 4 mill, carbs intakes etc etc etc pingel etc.Everything on the bike seems to be done perfectly.The only thing im not liking is when i put it in first gear it goes in hard and kinda wants to kill the bike, 1st gear is down.Its weird if i pull the clutch in with it in first gear it wont roll ( With bike Off )? But if i start the bike in N and keep the rpm off idle and put it in gear it kinda clicks in hard then it doesn't move and the clutch works normally and operates normally? I was told it has a 5 spd in it and im assuming its some sort of overide esp since the bikes in the 100 hp range.Just wondering if thats normal for the overide style transmissions? Or if some variation of them did that>? Once I get it in gear everything seems fine just goes in first weird and does that weird shit when the bike is off? any help is appreciated. Quote Link to comment Share on other sites More sharing options...
uwenr Posted October 26, 2009 Report Share Posted October 26, 2009 I just bought a bad ass banshee that has alot of mods done to it cheetah supercub 4 mill, carbs intakes etc etc etc pingel etc.Everything on the bike seems to be done perfectly.The only thing im not liking is when i put it in first gear it goes in hard and kinda wants to kill the bike, 1st gear is down.Its weird if i pull the clutch in with it in first gear it wont roll ( With bike Off )? But if i start the bike in N and keep the rpm off idle and put it in gear it kinda clicks in hard then it doesn't move and the clutch works normally and operates normally? I was told it has a 5 spd in it and im assuming its some sort of overide esp since the bikes in the 100 hp range.Just wondering if thats normal for the overide style transmissions? Or if some variation of them did that>? Once I get it in gear everything seems fine just goes in first weird and does that weird shit when the bike is off? any help is appreciated. That is not normal for an override, they should be as smooth or smoother than stock Quote Link to comment Share on other sites More sharing options...
peanut2 Posted October 26, 2009 Author Report Share Posted October 26, 2009 That is not normal for an override, they should be as smooth or smoother than stock What about any kinda clutchs? Would a lockout do that>? Once its in first the clutch works fine with it in gear and the clutch in it doesnt move? Anyone know. Quote Link to comment Share on other sites More sharing options...
peanut2 Posted October 26, 2009 Author Report Share Posted October 26, 2009 What about any kinda clutchs? Would a lockout do that>? Once its in first the clutch works fine with it in gear and the clutch in it doesnt move? Anyone know. You know what i think it might be the clutch plates sticking. I think im gonna go ride it then see if it still does it.It hasnt been riden in a few months Quote Link to comment Share on other sites More sharing options...
badassbanshee479 Posted October 27, 2009 Report Share Posted October 27, 2009 have you ever rode anything with an over ride trans? make sure to not back load the trans or you will bend shift forks and you will have to split the cases to fix it...... Quote Link to comment Share on other sites More sharing options...
lowriderb Posted October 27, 2009 Report Share Posted October 27, 2009 you may already have a sleightly bent shift fork, which can just happen over time. or the clutch may be out of adjustment or if you have an easy pull lever it will without a doubt cause the clutch to grab even though its adjusted correctly. Quote Link to comment Share on other sites More sharing options...
AKheathen Posted October 27, 2009 Report Share Posted October 27, 2009 it's normal for the clutch plates to stick a bit like that. give it enough force, and the tires will roll. only worry about that when it lunges foreward and creep with the clutch pulled in and running in gear. the gear clunk i don't know about. regular gears clink and grab just a little when you stick it in first with the clutch pulled. if you rev it up alot to take off, the lockup will do it's job and grab real well.... Quote Link to comment Share on other sites More sharing options...
peanut2 Posted October 27, 2009 Author Report Share Posted October 27, 2009 Its not really a clunk i cant desribe the sound it just wanted to grab was all with a low idle it killed the bike with the clutch pulled in when i put it in first then i brought it up off idle a lil bit and it went it Tick.Then the clutch worked fine the bike didnt wanna move with it in gear and the clutch in and the clutch worked fine im gonna go ride it today just need some dirt tires and ill see if it fixes the problem the bike hasnt been riden in several months. Quote Link to comment Share on other sites More sharing options...
AKheathen Posted October 27, 2009 Report Share Posted October 27, 2009 possibly, the plates are just sticky from sitting.........if it doesn't get better, then it's most likely the clutch basket worn Quote Link to comment Share on other sites More sharing options...
peanut2 Posted October 28, 2009 Author Report Share Posted October 28, 2009 Plates were sticky.Rode it around and it started getting better and better. Its fine just gotta see how much the arrows are allowed to be off? They seem to be strait on when there is a little bit off tension on the lever? i was told that is good. Quote Link to comment Share on other sites More sharing options...
badassbanshee479 Posted October 28, 2009 Report Share Posted October 28, 2009 sounds like the clutch is adjusted perfect if the arrows are lined up with light pressure Quote Link to comment Share on other sites More sharing options...
