soundman1 Posted October 21, 2009 Report Share Posted October 21, 2009 Hello all, The Banshee was getting pretty sluggish on the bottom end, but winds out good still. Before putting in new plugs, did a compression check. Left bank is 135 and right bank is 150. Reading that possibly cracked or broken reeds could be the culprit, if that's the case, wouldn't it crap out on the top end too? Any input appreciated. Thanks, Terry Quote Link to comment Share on other sites More sharing options...
black sunshine Posted October 21, 2009 Report Share Posted October 21, 2009 Don't think reeds are your problem. I'd do a leakdown test Quote Link to comment Share on other sites More sharing options...
soundman1 Posted October 22, 2009 Author Report Share Posted October 22, 2009 I should probably verify that I did the comp test correctly also. Only had the plug out of the cyl I was working on, throttle closed, filters on, and kick till the gauge topped out. Is that correct? Quote Link to comment Share on other sites More sharing options...
bbcmudtruck Posted October 22, 2009 Report Share Posted October 22, 2009 Take both plugs out when you do it. You may have just got a little tired and stopped a little before the guage did. Also, pin the throttle wide open. Quote Link to comment Share on other sites More sharing options...
soundman1 Posted October 22, 2009 Author Report Share Posted October 22, 2009 Thanks, will give that a try again tonight. Quote Link to comment Share on other sites More sharing options...
blowit Posted October 22, 2009 Report Share Posted October 22, 2009 Thanks, will give that a try again tonight. The reeds will not cause your change in compression. More than likely a piston/ring issue here. Brandon Mull Engineering Quote Link to comment Share on other sites More sharing options...
