batshee Posted October 20, 2009 Report Share Posted October 20, 2009 ok guys to my knowledge this bike has the following mods. cpi inframes stock reeds with spacers 28mm pwk's Not sure if ported or milled head uni foam filter pods br8es spark plugs sea level miami fl riding temps around 80f to 100f i think my main jet is a 160 and the air screw not sure where my dumb mechanic put it but after he jetted my bike shee still has a slight bogg at bottom end but a clean top Quote Link to comment Share on other sites More sharing options...
alf44 Posted October 20, 2009 Report Share Posted October 20, 2009 most of them do have a slight lowend bog. Ive been fighting the same thing for 2 seasons with mine. the cpi pipes are a more topend pipe also. Quote Link to comment Share on other sites More sharing options...
batshee Posted October 21, 2009 Author Report Share Posted October 21, 2009 So the slight bog can be from the cpi pipes .... Quote Link to comment Share on other sites More sharing options...
alf44 Posted October 21, 2009 Report Share Posted October 21, 2009 Proly. Runs great on the topend though right? Just make sure carb is tuned,intake bolts are tight and all the gaskets are good. If you can get your hands on some other pipes try them out. It all depends on what kind of riding you do to decide what pipes will work best for you. Quote Link to comment Share on other sites More sharing options...
GNR101 Posted October 21, 2009 Report Share Posted October 21, 2009 ok guys to my knowledge this bike has the following mods. cpi inframes stock reeds with spacers 28mm pwk's Not sure if ported or milled head uni foam filter pods br8es spark plugs sea level miami fl riding temps around 80f to 100f i think my main jet is a 160 and the air screw not sure where my dumb mechanic put it but after he jetted my bike shee still has a slight bogg at bottom end but a clean top what pilot and needle setting? 160 seems a rich.. ive got 155 main. on pwk 33s and im still rich. Quote Link to comment Share on other sites More sharing options...
