Stock shocks on wicked a arms
Loc
Of course you can. Just if there +2+1 or +3+1 arms, the shocks are going to be quite a bit more plush and maybe sag down a lil. But it will work for the time being.
So it will widen and lower the front. It will also make the front a little softer. That might not be to bad. I am pretty light weight 135lbs. So it probably won't hurt to much.
  • 1 month later...
If you can find a set of Yfz450 shocks for a great price then I would get those. They are a great shock and have alot of adjustment. You have rebound, compression and preload. Most of the after market lower grade shocks only come with preload and maybe compression adj. So if you want a great shock that has some great adj out of the box then get those. You can also make them into dual rate shocks later on down the road and get them revalved for your riding. With the stock shocks on the +2+1 arms they will fast fast... They arent made for that but will work for some easy trail riding.
