99bansheeworked Posted October 12, 2009 Report Share Posted October 12, 2009 hey before i get flamed yes i said reverse when i give it gas it will go back. I know when the piston hits all that.The ignition timing i thougtn but its fine. What else can it be. After i shut it down its fine but i think something def wrong Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted October 12, 2009 Report Share Posted October 12, 2009 What happened to make it do this,its kinda hard to understand with no background or history of an event that led up to this,I think timing but we need info Quote Link to comment Share on other sites More sharing options...
racer Posted October 12, 2009 Report Share Posted October 12, 2009 You're saying that when you start it, the tires turn in a direction other than forward? Knowing the starter, I don't think that's possible. Quote Link to comment Share on other sites More sharing options...
Drewski Posted October 12, 2009 Report Share Posted October 12, 2009 for those who think it is not possible to have a banshee run in reverse....it is....it's called deisleing. this happens when the timing is out or when pre ignition occurs forcing the piston in the opposite direction. i would take your stator off and check all the components to see if anything is loose. Quote Link to comment Share on other sites More sharing options...
TwistedSheeRida Posted October 12, 2009 Report Share Posted October 12, 2009 if you arent risking blowin the motor i would run it through the gears in reverse first just to see how it goes lol but def sounds like a timing issue Quote Link to comment Share on other sites More sharing options...
sinisterboo Posted October 12, 2009 Report Share Posted October 12, 2009 Kid brought me a blaster to work on once that was doing that, broken flywheel key was the culprit. And yes, I had to "test-ride" it first, to fully understand, LOL. quads are very responsive to steering going backwards fast! Quote Link to comment Share on other sites More sharing options...
bansheeseat$$ Posted October 12, 2009 Report Share Posted October 12, 2009 A crank out of faze will do this also(Twisted) Quote Link to comment Share on other sites More sharing options...
TwistedSheeRida Posted October 12, 2009 Report Share Posted October 12, 2009 A crank out of faze will do this also(Twisted) Cool! learn something new everyday Quote Link to comment Share on other sites More sharing options...
blowit Posted October 12, 2009 Report Share Posted October 12, 2009 for those who think it is not possible to have a banshee run in reverse....it is....it's called deisleing. this happens when the timing is out or when pre ignition occurs forcing the piston in the opposite direction. i would take your stator off and check all the components to see if anything is loose. Dieseling is actually a totally different phenomenon. This just sounds like the timing being far enough off to reverse the engine which is certainly possible. Dieseling refers to a type of compression ignition cycle. Brandon Quote Link to comment Share on other sites More sharing options...
Drewski Posted October 12, 2009 Report Share Posted October 12, 2009 Dieseling is actually a totally different phenomenon. This just sounds like the timing being far enough off to reverse the engine which is certainly possible. Dieseling refers to a type of compression ignition cycle. Brandon yes, my bad you are right but running an engine in reverse can be caused by deiseling Quote Link to comment Share on other sites More sharing options...
Screaming Yellow Zonker Posted October 12, 2009 Report Share Posted October 12, 2009 This can happen during a kick back also.. It has happened to a friend but he shut it down and restarted it and it was fine. Quote Link to comment Share on other sites More sharing options...
DallasGDub Posted October 12, 2009 Report Share Posted October 12, 2009 quads are very responsive to steering going backwards fast! Brings back memories of the mean green machine bigwheel!!! Quote Link to comment Share on other sites More sharing options...
99bansheeworked Posted October 13, 2009 Author Report Share Posted October 13, 2009 for those who think it is not possible to have a banshee run in reverse....it is....it's called deisleing. this happens when the timing is out or when pre ignition occurs forcing the piston in the opposite direction. i would take your stator off and check all the components to see if anything is loose. That is correct i looked at the timeing and broguth quad place they said they dont know lol Eh idk what else to do Quote Link to comment Share on other sites More sharing options...
