CUB cyilnders NEEDS a cub HEAD
stroking
I POSTED UP A TOPIC ABOUT THE COMPRESSION on this motor [120psi] a while back and today i decided to take the head off to have a look at the setup....well the head is completely stock 64mm.. and i rechecked the squish and its .110 on left and .108 on right...wayyy to big for a alcohol motor i think.....
i have a pic o how much needs to be cut out of this head to fit the cylinder.....oh and the piston was hitting the head on the very edge also.........good thing i tore it down to have a look.......why would someone put a stock..UNCUT head on cub cylinder i don't know.
this motor was bought like this,so i guess the seller just threw a head on there to make a quick sale
  • 2 weeks later...
i got a set of 68mm 18cc domes and the compression is now at 162psi,think i should have gotten 16 or 17cc domes.
but the bike runs ALOT better now....just can't get it to shift under a load
That sounds low to me with those domes whats the squish? How far are you from sealevel.
Something is still wrong with your compression #'s.With 18cc domes you should be more then 162 psi Unless your at 8000 ft above sea level.I run 18's in mine at 4500ft and have 185psi.
I agree im at 1000ft with 18s on a 65cub and got 193 cold the other day. That 68mm should be way up there with those domes.
im below sealevel in some area and 20ft above in others......both cylinders have the same comp so it can' be the rings.
You have something going on for sure. I wouldnt event put those domes in a 68mm cub at that elevation. Check the squish. What kinda gauge are you using? Might try another one. With that setup u should be way above 200psi cranking and I would guess 18/1. After reading the whole post starting to sound like you have a 4mm cub on a 54mm crank if the squish is .110. It should be around .050 or less.
Edited by RILS
I've also got 18cc domes in a 4mm cub and am around 160-165 psi. 1000 ft. elevation. I'm not worried about it though. Got a .020 base gasket in and squish around .050 I believe so I'm happy with it. Does great as an all-around cub motor. Did I think the compression should be higher? Yeah, but I'm not too worried about it.
The problem is that most compression gauges are garbage. I have a snap on gauge that has been tested and is accurate, and at sea level with 20cc domes on my 4milx68mm cub it kicked 185psi. That was with .050" squish and cleaned up ports. My guess is that your gauges are off
