GNR101 Posted October 8, 2009 Report Share Posted October 8, 2009 ok ive installed cpi inframe sb's on my banshee its sweet down low and in band but just as/b4 it hits band its stuttering (like a faulty plug) then hits band and cains any ideas what my issue is? and ive stuck new plugs in sparks good 160 mains 3mm smoke ring on plug chop 48 pilot CEL needle on the 3rd pwk 33mm trail/dune port k&n 6" filters thanks dave Quote Link to comment Share on other sites More sharing options...
RILS Posted October 8, 2009 Report Share Posted October 8, 2009 (edited) ok ive installed cpi inframe sb's on my banshee its sweet down low and in band but just as/b4 it hits band its stuttering (like a faulty plug) then hits band and cains any ideas what my issue is? and ive stuck new plugs in sparks good 160 mains 3mm smoke ring on plug chop 48 pilot CEL needle on the 3rd pwk 33mm trail/dune port k&n 6" filters thanks dave What elevation are you at? Did you just change the pipes or rejet as well? Im not a 33pwk expert but the jetting sounds pretty fat to me for a mild port. I would start leaning the needle first and then drop the pilot if necessary. What do your plugs look like after wot? Edited October 8, 2009 by RILS Quote Link to comment Share on other sites More sharing options...
GNR101 Posted October 8, 2009 Author Report Share Posted October 8, 2009 (edited) im at sea level and about 24 deg C yeh i change the jetting a little with the cpis ill try dropping the sizes then Edited October 8, 2009 by GNR101 Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted October 8, 2009 Report Share Posted October 8, 2009 I would drop the main a size down. See if you get a screaming top end. Then lower the needle one clip. Don't do them at the same time. You want to get the main 100% dialed in before you start messing with the needle. That way you don't mis adjust the needle to make up for the wrong main jet. Quote Link to comment Share on other sites More sharing options...
