AUSSIE BANSHEE Posted September 30, 2009 Report Posted September 30, 2009 I have just bought a Trail Tech Vapor. I am chasing some advice for wiring, the instructions supplied are generic for a couple of models. My main question is regarding the RPM. Has anyone wired straight to the orange wire at the coil or is the wrapping of the ignition lead a better way to go. Any input will be greatly appreciated. Quote
rubberneck Posted September 30, 2009 Report Posted September 30, 2009 I tried both ways and could never get the tach to be accurate. It was very erradic. I came to the conclusion that the banshee electrical system was just too damn noisy, and i was using resistor type plugs Quote
yfz350rider Posted September 30, 2009 Report Posted September 30, 2009 i ran the power off the yellow wire from the headlight switch. I tried several different ways to run the rpm wire, best luck i had was just takping it down on the sparkplug wire, i didnt wrap it, just ran it parallel with the wire maybe like 3 inches. My rpm read out seems pretty accurate, i just needed to switch the plugs to the BR8ES rather than B8ES. When running B8ES the computer would restart when i hit high r's. All in all i like the computer, the main feature that made me buy it was the temp readout and warning lights. Quote
bansheesandrider Posted October 1, 2009 Report Posted October 1, 2009 I tried to make a Vapor work on my Banshee and never got it to work, I even took it to Trail Tech and they couldn't get it to work either. When the water temp was below 100 degrees and i revved above 7000 the thing would do a full reset. Trail Tech tried hooking it up every way they knew of, they replaced all of the wiring and sensors and even the computer itself, but nothing worked. I had BR8ES plugs in it. I took it to them twice and between times I rode the bike and determined that reading the tach while riding was very difficult. When I took it to them the second time, I told them I didn't care about the tach, I just didn't want the thing to keep resetting. So they recommended I get the Vector model. I agreed to it and they GAVE me a Vector and let me keep the Vapor along with the spare sensors and wiring and one of their wire connector kits with a crimper. I am very happy with the Vector, since I mainly wanted to know temp., speed, and keep track of hours for maintainence. I found while riding the bike, you don't have time to watch the trail, tach, and shift lights, and you just end up shifting by feel/ear like I did without the tach. Since I still have the Vapor, I might try it on my wife's bike if I ever get time to put it on. Good luck. Quote
Invader Posted October 2, 2009 Report Posted October 2, 2009 i run mine off a 9 volt. I coiled the wire around the spark plug cap wire and it seems to work fine. but more interested in temp. Quote
AKheathen Posted December 4, 2009 Report Posted December 4, 2009 yah, i was really torn between the 2, because i wated the odometer features, but i want the tach more... Quote
bansheesandrider Posted December 6, 2009 Report Posted December 6, 2009 i run mine off a 9 volt. I coiled the wire around the spark plug cap wire and it seems to work fine. but more interested in temp. I tried the 9V trick also, it made no difference. It would even reset with the tach lead unhooked and removed from the bike. As far as the tach, I had a hard time reading it when I was just riding the bike around my open field behind the house, if I was in the dunes I figured that it would be more important to watch were I was going than looking at a tach. If I don't know when to shift it after riding it for 20 years, I should probably get rid of it. Now if I was drag racing it and thought a tach would improve consistency, I would go for it in a heartbeat. I think the Vector without the tach is great, but like I said, I mainly wanted a temp gauge, hourmeter for maintainence, and the speedo is great for speed runs on the flats at Florence. Quote
