Which Klotz oil do you use?
RippinShee
I have been running R50 at 40:1 for the last 15 years in all my 2 strokes, except the kids Blaster which I just took the injector off of. I have had zero problems with my motors running it. The top ends seem to last forever and when I pull the cylinders off, the crank has a good film of oil all over it. I used to run Benol, but had problems with carbon buildup in the rings on the wife's old Blaster. The R50 smells just fine to me, although that should be the last reason for choosing an oil, and I have found the brand and type of fuel makes a bigger difference in smell. The R 50 seems to burn clean with very little smoke. Just my 2 cents.
  • 2 weeks later...
I uas amsoil dominator and after 900 miles of riding, pulled the head to swap a gasket and the pistons are cleaner than they were a year ago. all the carbon gunk is gone and the domes looked perfect, no residue, no build up, just a nice clean piston with an even black coat on it. dont get much better than that in my opinion.
Overboost....what ratio are you running? I'm going to switch to Amsoil after my rebuild.
I also would like to know what ratio you're running over boost..
i had a couple gallons of the stuff i was running in my jet-ski.. but i threw it out because the bottle said it was meant for 100:1 applications
