SST install Problem (pics)
KrenzyRyan
Hey guys, I got some SST pipes for my Banshee and have ran into a problem.
As you can see from the pics, there is a large gap on the rear-most hanger. Is there suppose to be a bushing for this? And where may I find one/what does it look like?
Also, I seem to be leaking a bit of exhaust from this area (where the silencer connects to the pipe). Is this normal?
The exhaust mostly leeks from the top pic (and yes, the pipes are pushed into each other as far as they can go (with all hangers attached).
Edited by KrenzyRyan
All of the FMF silencers that I've ran in the past, have had a washer, rubber grommet, and an aluminum bushing that mounts the silencer to the frame, on both sides. You are missing some parts. You're probably going to have to call FMF to get the parts you need, as I've never saw the silencer mounts sold separately anywhere. Your pipes will leak where the silencer mounts up, unless you use the stock rubber hoses, and clamps, or buy some aftermarket pipe clamps. Cascade sells some, as well as many of the site sponsors.
Edited by fastbanshee8
as far as your union get some 3/4'' heater hose and use 1'' hose clamps on both sides, and yes the silencer does use a rubber bushing! a bolt and washer! no spacer! take one of your stingers to autozone, pep boys, orileys.. and go to the help me section
you will find all kinds of rubbers you will find some that work well!
