New top end compression? And clutch chatter?
Ok, so here goes nothing. I am super anal about my banshee and any noise out of the ordinary I immediatley diagnose and fix. Ok, so here is what I have some questions on. I have an '01 and I just rebuilt the top-end two weeks ago. Prior to the rebuild, I ran a compression test and had 60 lbs of pressure in each cylinder. I bored the cylinders .030 and put Wiseco pistons in it. So I ran a compression test yesterday after riding it at sandfest all weekend and I have 130 lbs of pressure in each cylinder. I assumed I would have at least 140 -150 lbs of pressure after a fresh top end rebuild. If anyone has any input, please share. What is stock pressure in each cylinder?. Ok, so on to the next question. I started it and ran it for a while yesterday after putting my dirt tires back on. I noticed a chattering noise coming from my clutch area. Its not the kickstarter either. I know the dunes are hard on clutches, so I might be in need of a new clutch. Has anyone else heard a chattering noise like this? and what did you do about it? If I tear apart, I'm gonna replace the entire clutch with a hinson basket and new metals and front and rear plates with heavy duty springs. The clutch currently in the bike is a stock clutch. Keep in mind, it is an '01. I'm just curious as if what I'm hearing is normal and if I'm freaking out over a little clutch basket chatter? Thanks guys for all the input, Like I said earlier, I'm a worry'er and I would rather spend the money now than get out riding and F the thing up worse and sit with a sad face.
  • Replies 30
  • Created
  • Last Reply
Top Posters In This Topic
IMO you should have more compression ! when you did your comp check were you holding the throttle wide open ? and clutch chatter is not normal pull the cover and take a look. and I believe stock comp is 145 someone please correct me if i am wrong as i would like to know to .
When I did the compression test the engine was cold and yes I had the throttle wide open. The Wiseco pistons are forged pistons therefore they swell a little bit when they warm up, that could have been the reason for only 130 lbs. of pressure????
Well, I just got off the phone with the dealership where I keep it and they're gonna check it out 2day. I never noticed it before I went to the sand dunes. I know the sand dunes are hard on clutches because ya gotta slip the clutch a lot more 2 get it to move. As for the cylinder pressure, I am going to get the engine to operating temp and then do a compression test tonight and see what it shows up as.
My banshee is a bastard child...lol!! I put all new front suspension on it, top end, chain and sprockets, new clutch and other crap. I enjoy messing with it, but damn I wish it would just run solid. The sand def played a tole on my clutch and now I'm looking for a hinson basket to solve all my problems.
are you running a stock head?if so,your comp.is just fine.
Yes, I have a stock head. I was just under the impression that a new top end would boost my compression up to around 140-150. What is a stock banshee compression? I want more HP from it after riding it this weekend. I rode my friends 100 hp banshee and WOW!...that was just sickening! I really would like to get a set of CPI drag pipes, but then I gotta re-jett it and other stuff.
