Justintoxicated Posted September 22, 2009 Report Share Posted September 22, 2009 (edited) I want to rewire my banshee using 2 of these switches so it works like this http://www.trailtech.net/040-HBS-02.html Switch 1 position 1 = Off Switch 1 position 2 = taillight + 1 headlight (Bottom Left) Switch 1 position 3 = taillight + 2 headlights (Bottom Left + Bottom Right) Switch 2 position 1 = Off Switch 2 position 2 = Top Left Headlight Switch 2 position 3 = Top Left + Top Right headlight I'm not sure how to wire up the kill switch though? (one of them anyways) edit: N/M I found the info. However I would feel much better if someone could verify this. http://www.trailtech.net/media/instructions/lights/switches/010-ELV-72.pdf Edited September 22, 2009 by Justintoxicated Quote Link to comment Share on other sites More sharing options...
Hilarious Posted September 22, 2009 Report Share Posted September 22, 2009 i am assuming you have removed everything including the key switch. where it says tap into the igniton wire between the cdi and coil, which would be the orange wire on our banshees. you should have a white/black striped wire running to the cdi. wire it into that instead. Quote Link to comment Share on other sites More sharing options...
Justintoxicated Posted September 22, 2009 Author Report Share Posted September 22, 2009 i am assuming you have removed everything including the key switch. where it says tap into the igniton wire between the cdi and coil, which would be the orange wire on our banshees. you should have a white/black striped wire running to the cdi. wire it into that instead. I think part of your msg got removed? Do I tap it into the orange wire or the Black and white one instead? I do still have my key installed. Quote Link to comment Share on other sites More sharing options...
Hilarious Posted September 23, 2009 Report Share Posted September 23, 2009 I think part of your msg got removed? Do I tap it into the orange wire or the Black and white one instead? I do still have my key installed. sorry about the confusion. you should be able to connect to the black/white striped wire. Quote Link to comment Share on other sites More sharing options...
