AKheathen Posted September 27, 2009 Report Share Posted September 27, 2009 catually, the ignition windings will light a test light really bright with one medial kick. i tried it last year out of sheer curiosity when a guy didn't have a meter. Quote Link to comment Share on other sites More sharing options...
bunga's Posted September 28, 2009 Author Report Share Posted September 28, 2009 put it in gear. you can use an impact driver which is 10-15 from harbor freight or online. i know rmatv has one. part # 1145050001. or, you can use a breaker bar and smack it with a hammer while holding pressure to unscrew it. if your stator ohms out within specs on the lighting, ignition, and pickup, and you aren't lighting up a bulb tester on either coil, then it's most likely the flywheel. if you need the puller asap, yamaha has them in stock and it fits other yamaha flywheels as well as some other makes. do you have the ohm specs? well yer thats what has me puzzled, all the coils come up good, i read the other post about corrosion in the flywheel. my one is brown lol like a old lawnmower hahaha very old but it doesnt look like it has had water in there. i might have to buy a puller and if its ugly i may as well replace the whole lot. every stator kit i seen on ebay i calle up and they dont have stock. unreal. Quote Link to comment Share on other sites More sharing options...
bunga's Posted September 28, 2009 Author Report Share Posted September 28, 2009 hey buddy where abouts are you, im in wickham and have a flywheel puller you can borrow. no lights or anything sounds like the stator has crapped itself. hey yer wickam. im in pannawonica. not far at all. Quote Link to comment Share on other sites More sharing options...
