high rev
mrbigsacks
Well whens the last time you put some seals in? If there real old yes it can suck air in and cause a lean condition and idle high
IMO you should just build a leak down tester real quick for $30 and just check and see if you have an air leak some place.
Or at least start the motor and spray soapy water all over the motor, carbs and intakes. If there is bubbles, there is your leak.
How to build a leak down tester quick>>>> http://bansheehq.com/forums/index.php?showtopic=110585
Edited by savage420
